Men Not Necessarily More Car-Care Savvy Than Women . . .
Old May 10, 2006 | 07:13 AM
Gojirra99's Avatar
Gojirra99
Default Men Not Necessarily More Car-Care Savvy Than Women . . .
Jiffy Lube Survey Shows Both Sexes Fall Short in Preventive Maintenance Knowledge
HOUSTON, May 10, 2006 -- Women who turn to men for car-care advice may not be getting good counsel as often as they think. A national survey sponsored by Jiffy Lube International found that while 69 percent of men and 64 percent of women think men know more than women on the subject, their responses to basic car-care questions tell a somewhat different story.
"With peak driving season approaching and gasoline prices rising, we decided to see if men really have any bragging rights when it comes to getting the most out of your vehicle -- and every gallon," said Jiffy Lube International technical expert Mark Ferner.
When asked where a vehicle's proper tire-inflation pressure information is located, 67 percent of men and 45 percent of women said on the tires' sidewalls. In fact, that's wrong. "Proper tire pressure is vehicle-specific," Ferner said. "Tire sidewalls list the maximum pressure recommended by the tire manufacturer. Proper tire pressure information for a vehicle is found on a decal typically in the vehicle's door jamb or in the vehicle owner's manual." Twenty-two percent of women -- more than the 16 percent of men -- realized the correct tire pressure is not on the tire sidewall, wheel rim or wheel well.
Two-thirds (67 percent) of men and 46 percent of women incorrectly assumed simply switching from conventional engine oil to synthetic oil enables the number of miles between oil changes to be safely extended. "Switching from conventional to synthetic oil is not an automatic license to extend a vehicle's oil-change interval," said Ferner. "The vehicle manufacturer's recommendations and the conditions in which you drive are also important. Most vehicle owners' manuals list two oil change intervals -- one for normal driving and the other for severe driving. If you idle excessively, or often drive in stop-and-go traffic or extreme weather conditions, your vehicle is likely a candidate for the severe service schedule."
The normal life expectancy for many windshield wiper blades is six to 12 months. While about half of the men and women polled (54 percent and 49 percent) knew this, nearly 40 percent of them (39 percent and 38 percent) answered anywhere from one to five years. "Many drivers don't think about the condition of their wiper blades until they're caught in foul weather," said Ferner. "Checking and replacing them as needed could improve visibility to avoid a very dangerous situation out on the road."
About half of men and women (50 percent and 48 percent) knew under- inflated tires, a dirty air filter, incorrect wheel alignment, and even a loose gasoline cap can all reduce gas mileage. Independent studies suggest that maintaining proper tire pressure and replacing a clogged air filter can save an average of 10 cents and 29 cents per gallon of gasoline, based on a per-gallon price of $2.90. "Avoiding fast starts and stops, speeding, and excessive idling can also help you get more miles out of every gallon of gasoline," Ferner said.
Men fared significantly better than women on only a few other car-care questions. Forty-seven percent of men versus 27 percent of women knew cabin air filters clean the air passengers breathe. "Many vehicles on the road today are equipped with cabin air filters that need periodic replacement -- and many drivers don't know it," said Ferner. "Many vehicle owners' manuals list how often a cabin air filter should be replaced."
Seventy eight percent of men versus 56 percent of women knew the primary purpose of antifreeze/coolant was to help control the temperature of a vehicle's engine. "Antifreeze/coolant also remains liquid in cold temperatures to help protect the engine during extreme-cold starts," Ferner said. "Servicing your vehicle's cooling system according to your vehicle manufacturer's recommendations can really help you avoid costly repairs down the line."
source : theautochannel
Old May 10, 2006 | 07:49 AM
T0ked's Avatar
T0ked
I just found it funny that this "survey" is coming from Jiffy Lube of all place... yup, the "experts" in automotive care. They probably asked people to go their shops, which in my book just negates this whole study to begin with.
Old May 10, 2006 | 09:09 AM
diablo1's Avatar
diablo1
Not to mention that the point of most of the questions is "Did you know that you actually have to check/replace everything more often than you probably think?" - it's obviously just a marketing tool to get people into the stores more often.
Old May 10, 2006 | 09:30 AM
AJL0365's Avatar
AJL0365
jiffy lube didnt put oil in one of our's rental cars, needs a new engine now
Rustito
Nov 1, 2014 08:53 AM
Gojirra99
Feb 27, 2008 07:45 PM
tella
Dec 7, 2006 01:07 PM
additude
Wheels, Tires & Brakes Forum
Feb 20, 2005 01:52 AM
