Daizen Steering Rack Bushings Install *56K Warning*
Old 03-27-06, 01:58 PM
D1GP
D1GP's Avatar
Default Daizen Steering Rack Bushings Install *56K Warning*
Here is the step by step install of the Steering Racking Bushings
For this section, you will need to use a wood piece for leverage and use a craw bar to ply it upwards so you are able to know off the old bushing
Old 03-27-06, 02:02 PM
D1GP
D1GP's Avatar
There is another bushing behind the first one. You can press it out pretty easily
Notice how the old rubber bushing on the left is completely tore up
After you re-insert all the new Daizen bushings, just screw everything back on and you are ready to go. After this installation of bushings, you will need to do an alignment.
To purchase these bushings. Visit www.tmengineering.net
Old 03-27-06, 02:03 PM
Sly Guy Yu
Sly Guy Yu's Avatar
nice, really appreciate ur 2nd write up too.
Old 03-27-06, 02:25 PM
Lexiss_sc430
Lexiss_sc430's Avatar
Thank you very much for the write up,
I wanted to know your opinion and thoughts.... what did you think about this "upgrade" I wanted to do this and the sway bar bushing too... what pros and cons if any did you notice?
Thanks once again for the write up.... very well done
Tommy
Old 03-27-06, 02:36 PM
VJ RC51
VJ RC51's Avatar
oh good the daizens are metal. The other ones the other big lexus site sells have plastic spacers. I shattered those within weeks.
Old 03-27-06, 05:05 PM
neurocity
Neu`roc´i`ty
neurocity's Avatar
What perfect timing!!! I'm going to tackle this this weekend!!!
Old 03-27-06, 05:57 PM
One HoT
One HoT's Avatar
Great write-up..This mod is worth every penny..
I had this installed on my car for a month now...My mechanic had to drop my whole steering rack to get to both bushings on my V8 motor...I asked him if there was a short cut to it, he said that taking out whole rack was the only way to get to all the bushings..On the SC300, you can do as described on this thread but, on the SC400 it seems like you have a journey ahead of you...
Old 03-27-06, 08:27 PM
LexAnt
LexAnt's Avatar
weird, my mechanic was able to replace them all on my sc4 without removing the whole steering rack.
Old 03-27-06, 09:29 PM
lighthalo
lighthalo's Avatar
how much did it cost to have some one else do it?
Old 03-27-06, 11:34 PM
D1GP
D1GP's Avatar
Tommy
For the Steering Rack Bushings, There are only "Pros" to this upgrade. The steering feels much tighter and agile. You also feel the road a lot more making the SC into a sports car instead of a boat. Steering Rack bushings are the cheapest upgrade. Its only 40 Dollars!! You can pretty much install it yourself if you follow the step by step instruction on the top. Good Luck. Check out
http://www.tmengineering.net/suspens...n/make/sc.html for pricing.
Old 03-27-06, 11:42 PM
Overclocker
G35x - RWD/AWD goodness
Overclocker's Avatar
Very nice photo walk through D1GP. Thanks!
Old 03-28-06, 09:19 AM
VJ RC51
VJ RC51's Avatar
Oh i figured out why i keep eatting thru steering rack bushings.....
I leave the wire unhooked on the rack, so my steering is always in "highway mode", nice and firm. At slow speeds it puts alot of force on parts that dont normally see it.
Old 03-29-06, 01:44 AM
lighthalo
lighthalo's Avatar
on tm engineering.. it says you dont need to do an alignment... did you do one? jw gonna tackle this soon
Old 03-30-06, 12:37 AM
D1GP
D1GP's Avatar
I did an alignment because I had my lower and upper control arm bushings changed out as well. Maybe its from that that my steering angle is all jacked up. But if you get steering rack bushings done right, you don't have to.
Old 03-30-06, 01:34 PM
AME_VIP
AME_VIP's Avatar
Great pics thank you!!
You would have to get an alignment for the LCA's because they have eccentric camber bolts on the bottom. I don't see any reason why you would need an alignment after doing the steering rack bushings. The rack gets installed back in the exact same position.
Quick Reply: Daizen Steering Rack Bushings Install *56K Warning*
