Aftermarket HID Installation WITH PICTURES
Old 12-18-05, 09:57 PM
muzzman1
muzzman1's Avatar
Default Aftermarket HID Installation WITH PICTURES
So the 1st pic is what my stock halogen lights looked on my garage door.
Old 12-18-05, 09:58 PM
muzzman1
muzzman1's Avatar
Driver Side w/o engine cover
Passanger Side No Engine Cover
Old 12-18-05, 09:59 PM
muzzman1
muzzman1's Avatar
Removal of the airbox below. Two 10mm bolts hold down the box, but the mass airflow sensor and wire loom must be disconnected from it. Also the front air intake 10mm bolt and clip must be removed, the throttle body clamp must be loosened as well.
This is what the passenger side light fixture looks like after removing the cover and bulb.
Driver side after 10mm bolt removes washer fluid fill tube
1" hole in light fixture cover to allow for new wire installation
Old 12-18-05, 10:00 PM
muzzman1
muzzman1's Avatar
Rubber Grommet to seal out moisture
Fixture Side
Kit plugs directly into stock loom (Blue is Positive) I tested with a volt meter to be sure
Passenger side before cover re-installation
Old 12-18-05, 10:02 PM
muzzman1
muzzman1's Avatar
I parked the balast on the frame rail on the passenger side then zip-tied it to the existing wire loom
Driver's side cover
This is the driver's side balast, I sprayed it flat black to make it more inconspicuous, (then i scratched it) installed it next to the ECU and tied it to the wire loom
Garage door after the install
The install took less then an hour. The lights are 4500K. I chose this color temp because I wanted to preserve the stock appearance. The light illuminate the road exactly as well as my IS300...same color same intesity. The Kit was a "proxenon" It was $278 with a 2yr warranty. And claim that they provide "Hella" ballasts. The sales guy was "joe" very helpful in helping me decide exactly what kit I wanted. I bought them on Ebay (Sorry about the multi postings, but after having created the whole single post the website restricted the # of images)
Old 12-18-05, 10:04 PM
mofogasm
mofogasm's Avatar
nice guide, did the rubber grommet come with the HID Kit?
Old 12-18-05, 10:09 PM
muzzman1
muzzman1's Avatar
Yep the kit was complete, all I needed was a 10mm, socket, phillips, flathead, 1" hole saw.
Old 12-18-05, 10:17 PM
koolaidman
koolaidman's Avatar
err not liking how u had 2 terminals going str8 into the connector. ive seen on a few occations where they pulled out and caused a fire
otherwise nice setup
Old 12-18-05, 10:22 PM
muzzman1
muzzman1's Avatar
A fire with 12v....not too worried....I wrapped them with tape prior to final install
Old 12-19-05, 07:17 AM
United #10
United #10's Avatar
NIce work!! the HID kit looks good.
Old 12-19-05, 08:44 AM
Tropheus
Tropheus's Avatar
Hey, great pictures! Nice and clean installation.
Do you have a link to the Ebay website? Thanks.
Old 12-19-05, 08:49 AM
tim817
tim817's Avatar
Damn, I wish my kit came with those Rubber Grommet . Mine i just snap the dust cover back in and leave the wires stick out on the bottom. I didn't show any gap from the top of the dust cap but if u use ur finger to feel, there's gap on the bottom. I think a lot of people here are doing like that. Not sure that will cause any condensation.
Old 12-21-05, 09:09 AM
shaolin
shaolin's Avatar
does the stock HID has auto level adjusting??
Old 12-21-05, 10:07 AM
muzzman1
muzzman1's Avatar
im not sure I understand the question so i will answer it "both" ways....
The OEM HID does have an auto-leveling feature, and adaptive lighting, so the light follow the sterring wheel
The halogen version of the IS lights are NOT auto-leveling....so no the pictures you see above are my lights and they are stationary
Old 12-21-05, 11:05 AM
shaolin
shaolin's Avatar
icic.. any idea how much the factory cost? i know they might don't have it in stock but some of you guys might now..
Quick Reply: Aftermarket HID Installation WITH PICTURES
