Old 12-16-14, 12:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
Print Wikipost
DIY sparkplugs GS400*******************
Old 06-20-05, 01:43 PM
TLW
TLW's Avatar
Default DIY sparkplugs GS400*******************
hello all
just changed the sparkplugs on a GS400
this is how to do it
tool you will need
10mm deep 1/4 inch socket and ratchetr
one deep Sparkplug socket 5/8
some extensions
one stubby ratchet and a normal ratchet
very easy
ready on the coil pack there is a 10mm bolt ..loosne that and remove coil pack
the coil pack might be a little stubborn but it will free it self ....twist side to side
now take the deep 5/8 sparkplug socket slide into the hole and take out the sparkplug
see how easy that was
put the sparkplug carefully in the deep socket and once carefully insert into the hole
you dont want to mess up the gap
snug it up ,put the coil pack on and put the 10mm bolt back in snug it up
and thats it
i did all eight in less than hour ....the passenger side is easier
good luck
johnny
here some pics
10mm socket and 1/4 inch wrench
deep spark plug socket 5/8
10 mm bolt and the coil pack
coil pack removed
spark plug out
Old 06-20-05, 02:25 PM
noop
noop's Avatar
Cool write up , whats a good kind of spark plug to use?
Old 06-20-05, 02:29 PM
LB Lex
LB Lex's Avatar
Nice write-up I also heard that anti-seize compound should be used on the spark plug threads so they do not seize to the aluminum heads.
Old 06-20-05, 02:38 PM
TLW
TLW's Avatar
you know i heard this too ...but i didnt do it this time
the sparkplugs i used are
NGK BKR7-EIX
now these are for the FI GS's
but tthe website is
www.sparkplugs.com
just plug in your car
I almost forgot to thank DaveGS4 ..this place is great the prices are awesome and the overnight is very helpful when you neeed it
Thanks again Dave
Old 06-20-05, 02:42 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,127 Likes on 1,297 Posts
Originally Posted by T.L.W.
Thanks again Dave
Not a problem, that's why we're all here . Thanks for the writeup!
If I were not FI, I'd buy Torquemaster plugs to put back into my GS4... I still might do it with FI if I can get the colder plugs. Steve G has just opened up a group buy on them.
https://www.clublexus.com/forums/sho...d.php?t=167426
Old 06-20-05, 02:46 PM
TLW
TLW's Avatar
i was wondering if that was even an option ...hmmmm
ill keep these for a while ...let meknow if you change and notice a difference
Old 06-20-05, 02:51 PM
LB Lex
LB Lex's Avatar
NGK BKR7-EIX
but tthe website is
www.sparkplugs.com
Thanks again Dave
Did you get the right plugs or is the part number you provided a typo. It says the plugs you got (NGK BKR7-EIX) are for a Volvo http://www.sparkplugs.com/results_fi...pid=BKR7%2DEIX
The NGK plug for the GS4 is BKR6EIX-11 http://www.sparkplugs.com/results_ap...1&AAIA=1356072
Old 06-20-05, 02:56 PM
TLW
TLW's Avatar
https://www.clublexus.com/forums/sho...d.php?t=151204
read this my good man
Old 06-20-05, 02:59 PM
LB Lex
LB Lex's Avatar
I see, I forgot that you are FI.
Old 06-20-05, 03:28 PM
chuckb
chuckb's Avatar
how did the old ones look?
Old 06-20-05, 03:31 PM
TLW
TLW's Avatar
compared to the new ones ..dirty
Old 06-21-05, 04:25 AM
LEXUS_KID
LEXUS_KID's Avatar
Way to go Johnny What a way for everyone to save a few bucks the dealer charges $299 labor plus around $100 for the plugs nice write up
Old 11-01-05, 08:32 PM
EFMJR
EFMJR's Avatar
OK, this is probably a stupid question, but what is ment by FI GS? Ive been stumbling across this a few times and am puzzled. Please help the clueless person here. Thanks
Old 11-01-05, 08:36 PM
chuckb
chuckb's Avatar
forced induction
Old 11-01-05, 09:15 PM
EFMJR
EFMJR's Avatar
forced induction
Ohhh, I kinda thought that, but wanted to make sure it wasnt some rare type or something. Thanks
Quick Reply: DIY sparkplugs GS400*******************
