How to Fix Cupholder Ejection - Pictorial
Old 04-12-05, 09:08 PM
Lexbox
Lexbox's Avatar
Default How to Fix Cupholder Ejection - Pictorial
I have a habit of opening everything that is broke. For some reason I didnt do it when I had this problem on my cupholder about 1.5 years ago. I bought a new cupholder ashtray assembly and went on my way. One day I was about to put a drink in the holder and the frickin door would not eject. I knew after just replacing it that there was no way it could be broke. It was brand new for only $25 on Ebay. Steal! So I went on my way of figuring out what was wrong. What I found was one of the easiest fixes of all time. So here goes.
This guide is for you if your cupholder does not eject automatically like it used to. AND, its not because of a broken arm ring thingamajig (technical term).
*Drop the shifter, dont forget parking brake!*
1. Remove cupholder/ashtray assembly.
a. Pop woodgrain around shifter.
b. Remove lower screws securing the unit.
c. Remove the cosmetic black radio ring (stock only)
d. Remove upper screws from the unit
Attached Thumbnails How to Fix Cupholder Ejection - Pictorial-cupholder-001-small-.jpg
ELForce (10-14-20)
Old 04-12-05, 09:10 PM
Lexbox
Lexbox's Avatar
Default Gulp
2. Remove the top screws (2 on each side)
Attached Thumbnails How to Fix Cupholder Ejection - Pictorial-cupholder-002-small-.jpg
ELForce (10-14-20)
Old 04-12-05, 09:11 PM
Lexbox
Lexbox's Avatar
Default Pluck Pluck Pluck
3. Pluck the top cupholder mechanism from the rest of the unit like so
Attached Thumbnails How to Fix Cupholder Ejection - Pictorial-cupholder-005-small-.jpg
ELForce (10-14-20)
Old 04-12-05, 09:12 PM
Lexbox
Lexbox's Avatar
Default Flipper
Flip it upside down and it should look like this
Attached Thumbnails How to Fix Cupholder Ejection - Pictorial-cupholder-006-small-.jpg
ELForce (10-14-20)
Old 04-12-05, 09:14 PM
Lexbox
Lexbox's Avatar
4. As best you can, slide the cupholder out from the default position like so.
5. There are two black tabs that prevent the cupholder from over-extending. They are also blocking us from getting to the source. Remove the screw on each side and carefully set the tabs aside.
*This is my old cupholder so ignore the broken arm*
Attached Thumbnails How to Fix Cupholder Ejection - Pictorial-cupholder-009-small-.jpg
ELForce (10-14-20)
Old 04-12-05, 09:24 PM
Lexbox
Lexbox's Avatar
Default At last. We have located the source
Flip it over and you should see this. I have circled the problem as you see here. They kinda remind me of old school film.
Attached Thumbnails How to Fix Cupholder Ejection - Pictorial-cupholder-010-small-.jpg
ELForce (10-14-20)
Old 04-12-05, 09:27 PM
Lexbox
Lexbox's Avatar
What we have here is two different spinning mechanisms. The lower one with the copper coil has a "hammerhead" like hook on the end that came loose from the upper spinning mechanism. In this pic I have stretched out the coil that "powers" the eject process.
Attached Thumbnails How to Fix Cupholder Ejection - Pictorial-cupholder-013-small-.jpg
ELForce (10-14-20)
Old 04-12-05, 09:30 PM
Lexbox
Lexbox's Avatar
The hook deal on the end goes inside here.
6. Insert the hook head copper piece into the receiving gear mechanism.
Attached Thumbnails How to Fix Cupholder Ejection - Pictorial-cupholder-020-small-.jpg
ELForce (10-14-20)
Old 04-12-05, 09:31 PM
Lexbox
Lexbox's Avatar
Do I need to put some hair on it!?! Can I say that?
Attached Thumbnails How to Fix Cupholder Ejection - Pictorial-cupholder-021-small-.jpg
ELForce (10-14-20)
Old 04-12-05, 09:34 PM
Lexbox
Lexbox's Avatar
Default Phew!
Phew! We are finally done.
7. Reassemble the cupholder making sure not to forget the little tabs.
Sit back and enjoy.
Attached Thumbnails How to Fix Cupholder Ejection - Pictorial-cupholder-024-small-.jpg
ELForce (10-14-20)
Old 04-12-05, 09:38 PM
Lexbox
Lexbox's Avatar
Default Thanks for waiting
Thanks for waiting everyone. Hope to bring some joy to anyones "broken" cupholder.
ELForce (10-14-20)
Old 04-12-05, 10:34 PM
juan01
juan01's Avatar
You're on a roll!
Old 05-07-05, 05:47 PM
Ponteck2
Ponteck2's Avatar
Cool write up. I'm a newbie do you have to remove the center armrest consol to do this?
Old 05-08-05, 11:58 AM
Lexbox
Lexbox's Avatar
Negative
1. You have to pop the woodgrain around the shifter.
2. Remove black cosmetic insert at the bottom of the stock radio (if necessary).
3. This reveals 4 screws total to remove the cupholder (2 on the top, 2 on the bottom).
Old 05-07-06, 12:23 AM
tuan92129
tuan92129's Avatar
Can you explain the "popping the wood grain" part please?
I'm afraid i might damage something with my lack of technical skills.
Quick Reply: How to Fix Cupholder Ejection - Pictorial
