Seafoam experts, check in here.
Old 03-19-05, 04:44 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Default Seafoam experts, check in here.
OK, i am going to compile a seafom thread with all the PROPER info (since it is spread out in a million threads). There are several ways to use seafoam, i actually used it in my gas, most of you prefer the intake, some go for the oil.
Anyone that has used it please sign in here with setp by step instructions, helpful hints, do's and DO NOT's. I'd like to hear from oil, gas, and intake guy's if possible.
We'll be using this thread in the future. Thanks
Old 03-20-05, 07:44 AM
blaznsc4
blaznsc4's Avatar
i have use seafoam for my sc400. the way i did it was that i put 1/3 of it in the oil (to the block), 1/3 in the gas tank, and 1/3 to the fuel injectors. that way you'll get a thorough clean through out the whole system. for me to clean the fuel injectors i used a compressed air fuel injection cleaning pump. i drove the car around the block a couple times so that it would clean everything. the most important thing about using seafoam is that you will have to do a oil change after you drive the car around.
Old 03-20-05, 01:44 PM
southernsc
southernsc's Avatar
seafoam? im so lost as to what yall are talking about.
Old 03-20-05, 01:47 PM
/Aerostar\
/Aerostar\'s Avatar
Old 03-20-05, 05:26 PM
sourcemine
sourcemine's Avatar
Never used it, hear it awesome stuff..
Old 03-21-05, 04:02 AM
chitwnsazn
chitwnsazn's Avatar
yeap that's exactly how I used it
Old 03-21-05, 05:51 AM
blaznsc4
blaznsc4's Avatar
yup seafoam really works. you'll also get better gas mileage
Old 03-21-05, 10:06 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
This will be a part of the "my car stalls, what could it be" FAQ i am working on
Old 03-21-05, 10:36 PM
Shellhouse
Shellhouse's Avatar
I usually take the plugs out,
spray Mopar combustion chamber cleaner (think aerosol seafoam that foams) in each plug hole till it foams out and let sit overnight,
cover the plug holes (not by putting anything in them directly) and spin the engine over to make sure the stuff is drained from the cylinders,
put plugs back,
start the car and burn the rest out,
pour a can of seafoam into the intake as it runs (PCV or preferrably TB if the car will run with no intake pipe),
run until the exhaust is clear,
change or clean plugs,
change oil,
and that's it.
I stick to fuel injection cleaner for fuel treatment and kerosene/crankcase cleaner for oil treatment..
Old 03-24-05, 04:47 PM
lilnard85
lilnard85's Avatar
Default seafoam
hey guys
tofay i used seafoam to clean inside the engine out. It works great , i can tell the differance in the cars power.
I put some in the crankcase or oil put some in the gas and i also put some throught the brake line.
I was think that i will have to change the oil, and the fuel filter do you guys think that this would be a good idea
Old 03-24-05, 04:52 PM
indypwr
indypwr's Avatar
what are the procedures on doing this? im skeptical on doing this to my car......so
give us some feedback...
Old 03-24-05, 05:08 PM
/Aerostar\
/Aerostar\'s Avatar
Originally Posted by lilnard85
hey guys
You NEED to change the oil now, but the fuel filter probably was not affected by it.
Old 03-24-05, 05:23 PM
lilnard85
lilnard85's Avatar
ok thanks i will do that tomorrow, waht do you think about the spark plugs?
Old 03-24-05, 05:27 PM
/Aerostar\
/Aerostar\'s Avatar
Most people say you should change out your sparkplugs after doing this, as it probably fouled them up real nice. Thats the only reason I havent done this, I changed mine out a few months ago for Denso Iridiums and I dont feel like replacing them again.
Old 03-24-05, 11:17 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
go get some cheapies for $2 each from autozone and put them in before you do it if you have new plugs.
Quick Reply: Seafoam experts, check in here.
