The sound of water running .....
Old 02-12-05, 09:43 AM
TLW
TLW's Avatar
Default The sound of water running .....
has anyone else felt like when you step on the gas you hear like there is water running
could be coming from the sunroof but im not sure but i hear this alot
any clues ???/
Old 02-12-05, 09:51 AM
Richie
Richie's Avatar
Could it be the gas going to the engine, LOL
Old 02-12-05, 09:52 AM
TLW
TLW's Avatar
LOL it might be
i feel like its over head maybe something is clogged not sure
anyone else ??
Old 02-12-05, 10:30 AM
rheiy
rheiy's Avatar
Originally Posted by T.L.W.
LOL it might be
anyone else ??
That's strange only time I hear water is when its raining.
Old 02-12-05, 10:40 AM
GammaLex
GammaLex's Avatar
I heard bubbling once. It was becuase my coolent was low.
Old 02-12-05, 12:41 PM
Lexis11
Lexis11's Avatar
Johnny to me it sounds like there is something rolling around behind the radio but I removed to make sure there wasn't anything and there wasn't so ya I hear on the water running thing. (wow does that make any sense?)
Old 02-12-05, 01:04 PM
BlazenHazn
BlazenHazn's Avatar
Yes, i know this noise. It used to be real bad in my old car, i was told it has something to do with coolant lines. I usually hear it in the winter up north, when i first start the car and run the heat while the thermostat opens..
Old 02-12-05, 01:05 PM
LasVegasGS
LasVegasGS's Avatar
I've been geting that in the SC400 the last few weeks it started to **** me off yesterday. Only happens when you get on it hard.
Old 02-12-05, 01:19 PM
doug_999
doug_999's Avatar
Its air bubbles going through your heater core. Unfortunately air bubbles tend to get in there when you have a head gasket leak. I know this sound all too well from my Supra days.
You can try having the system flushed - but if it comes back.... you are in for fun.
Old 02-12-05, 01:56 PM
LasVegasGS
LasVegasGS's Avatar
So its better to just leave it alone, Will it come back worse if it does come back?
Old 02-12-05, 02:11 PM
doug_999
doug_999's Avatar
Na, if you got it you got it. Watch for things like your heat to stop working and keep a close eye on your temp gauge. One of the issues with air in the system is that air can get trapped near the temp sender - so it doesn't register and then all the sudden it skyrockets (when water hits it). If either of these things start happening (wild swings in temp and/or heat that stops working all the sudden) then get the thing looked at.
Old 02-12-05, 02:30 PM
TTurboPimp
TTurboPimp's Avatar
I have had that in a few different cars, its coming form the dashboard area.....it sounds like water bubbling/ gurgling. I had it in both of my Supras, my last GS, my Escalade......its nothing to be too concerned about. I had an explanation givent o me once, but I cant remember exactly what they said.....something to do with the heater core....blah, blah ,blah
Old 02-12-05, 02:32 PM
fasted1953
fasted1953's Avatar
I've had this twice. Happened when the quick lube oil change place took the radiator cap off a hot engine to check the fluid. Air gets in, and the air bubble works its way into the heater core... no valve to keep it out (according to Lexus of Austin). When I had the car in, they purged the air. Didn't tell me how they did it. In spite of the Lexus extended warranty, I was charged $10 or 15 bucks to have it fixed. Now I tell the oil change place to not check the coolant level or quality.
No reason to put up with it though; especially at 15 bucks to fix it.
Old 02-12-05, 03:01 PM
TLW
TLW's Avatar
thanks guys
at first i thought it was just me
you guys are swell
Old 02-12-05, 04:11 PM
3dog
3dog's Avatar
Smile
Hey Doug I'm glad to see that you are still around and offering good sound advice!
I was afraid you might have left us!
Ivan
3dog
Quick Reply: The sound of water running .....
