GS - 1st Gen (1993-1997) Discussion about the first generation GS300
how to take off shifter and woodgrain
Old 04-06-07, 11:05 AM
pingpong89
pingpong89's Avatar
Originally Posted by johnee78
You must first remove the ashtray and then on the base of the shifter there is a plastic cover that slides down..When you slide it down there are 2 screws that you remove and the shifter comes right off..Once this is done you pry up the back of the plate and also lift it from the front were you removed the ashtray.. Hope this helps..
how does the ashtray come out? do i pull on the ashtray itself or do i pry on the entire assembly?
Old 04-06-07, 11:09 AM
johnee78
johnee78's Avatar
Wink
You have to put the shifter in 2 so that you have room to remove the ashtray..Open the ashtray and pull/wiggle from the door on the ashtray..Once the ashtray loosens up pull from either corner that pops out first..the rest is self explanitory..
Old 04-07-07, 10:54 AM
pingpong89
pingpong89's Avatar
thanks johnee78, ill give that a shot.
Old 05-02-15, 08:24 PM
Muisak
Muisak's Avatar
Default Polished Aluminum
Here's how it looks if you just peel the first layer of wood off and polish the aluminum. No, its not the best looking way, but if you're tight on funds, it'll suffice.
Attached Thumbnails how to take off shifter and woodgrain-11168584_10155540312565790_4944812804053672776_o.jpg
lex97h
LX - 3rd Gen (2008-2021)
03-13-18 08:01 AM
xbladex00
02-23-16 05:00 PM
nikovdh
06-25-14 02:21 AM
chashiubow
Performance & Maintenance
11-14-08 09:23 PM
DroppedGS
14
04-12-03 11:42 AM
Quick Reply: how to take off shifter and woodgrain
