Old 12-16-14, 11:44 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Brake Guides
Print Wikipost
Brake pad and rotor change
Old 08-09-04, 07:39 PM
lexusk8
lexusk8's Avatar
Lightbulb Brake pad and rotor change
My friend who's an expert at fixing up American and Japanese cars helped me change the front brakes on my ES last weekend. The only reason I went to my friend for assistance (instead of doing the job myself) was that he had all the tools (i.e. garage jack stand, torque wrench, various metric sockets, etc).
OK, here are all the steps I can remember from the brake job:
1) While the tire is on the ground, loosen the lug nuts (don't forget your wheel lock key if your wheels came with wheel locks). My friend and I discovered that one of my front wheels had been overtorqued to at least 150 ft-lbs by some dumb technician who decided to use an air gun instead of a torque wrench when he checked my brakes last month. This may be one of the reasons why my rotors are warped Important lesson to learn: Never use an air gun to tighten your lug nuts; always use a torque wrench and torque the nuts to the proper factory torque setting.
2) Go ahead and jack up the car and take the lug nuts and wheel off.
3) Behind the brake piston assembly there are two 17mm bolts holding the assembly to the rotor. Remove both of those bolts (you may have to resort using extra pressure if the bolts have never been taken out).
4) Set the piston assembly aside (i.e. laying it on a bucket or hanging it on some wire). Be careful not to put any strain on the brake lines as you could mess up the ABS sensor.
5) By now your brake job should look something like this:
You should see (2) 10-24 pitch threaded holes on the inner bolt circle of the rotor. You will need to find a couple bolts that will fit in those holes (e.g. 12 mm size) and force the rotor to come out. That was the tricky part that I probably couldn't have figured out if my friend didn't help me
6) After taking the old rotor out, use some WD-40 on the small hub and clean up and prepare the area for interfacing with the new rotor. Time to put your new rotor in.
7) Take out your old brake pads from the caliper, and remove the metal shims from the pads (remember which shims go to which orientation on the brake pads). Clip the shims onto the new brake pads, and place the new brake pads into the caliper the same way as with your old pads. It is not necessary here, but we put in some Brake Quiet fluid (http://www.carwashwarehouse.com/TEC99220.php) on the used sides of the brake pads for better convenience.
8) Before putting the piston assembly back into place with the rotor, open the hood, place some rags around the brake fluid reservoir and remove some brake fluid. Do not let the brake fluid touch the paint!
9) You want to push the brake piston all the way away from the rotor using a C-clamp or some other means. The idea here is ensure a tight and secured fit of the brake pad part of the piston onto the rotor. This piston pressure fit step also affects the level of your brake fluid, so make sure it doesn't overflow.
10) Put the piston assembly back into place with the rotor. Before putting the wheel back in, it is a good idea to lay some anti-sieze grease over the lug nut bolts so it will be easier to take the wheel and rotor off the next time.
11) Put the wheel and lug nuts back in, finger-tighten all nuts in 5-star fashion, and use a torque wrench to torque the nuts in 5-star fashion.
12) Take your car out for a test drive and test the brakes at slow and abrupt stops separately. If everything checks out OK, mission accomplished Take note of the miles on your odometer so you know the history of your brake change.
I attached a picture of my new front brakes (please mind the curbed lip on the wheel). The blue stuff on the brake assy is the Brake Quiet applicant.
Other related links on changing brakes:
http://www.lexls.com/front_brake_rotor.html
http://lexusmodz.netfirms.com/GS_DIY/change_rotor
http://lexusmodz.netfirms.com/GS_DIY...ers/index.html
pickd4prez (05-31-22)
Old 08-09-04, 08:30 PM
juan01
juan01's Avatar
Nice write up Doug.
Old 08-10-04, 07:31 PM
GATO
GATO's Avatar
wait a minute Doug....can I call you Doug .....whats that yellow mark on top of the rotor? cause I got the same yellow mark.
Old 08-10-04, 07:33 PM
GATO
GATO's Avatar
t
Old 08-10-04, 08:35 PM
lexusk8
lexusk8's Avatar
I noticed that yellow mark too when we did the brake job. I'm assuming that's just one of a few reference markings made by the factory when the car was first produced, so I'm not worried about it.
Old 08-11-04, 08:17 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
With the newly done brakes, now you need to clean up and paint those calipers!
Old 08-11-04, 09:00 PM
lexsterES
lexsterES's Avatar
That’s funny; this whole time I thought that some random mechanic did that to my car. I feel a lot better since I'm not the only one with that
Great post Doug!
Old 08-11-04, 09:37 PM
juan01
juan01's Avatar
oh yeah, just noticed that yellow thing too
Old 07-26-05, 09:00 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Just saw the right up on the brakes... I really need to do this also with 65k on the car.... So, What ft./lbs of torque do you use for the caliper bolts and do you have to bleed the brakes? I guess not if your not taking the brake line off right?... Looks like a simple job that may take about an hour.... Also whats a good website to get OEM brake rotors and pads from? Thanks
Tony
Old 07-26-05, 09:53 AM
lexusk8
lexusk8's Avatar
Tony, we didn't put a torque spec on the caliper bolts; I believe we just tightened them down with the appropriate wrench. Now, if you're talking about lug nuts, then you'd have to torque the bolts down to 76 ft-lbs (and don't forget to fasten them in a criss-cross fashion).
Bleeding the brakes is not necessary when changing the brakes, unless you plan to change out the brake lines.
The best place I've found for purchasing OEM brake pads and rotors is http://www.irontoad.com. They're actually the parts department of a Lexus dealership in PA, and the prices are discounted much more than locally. Shipping is fast, and service is top-notch
Old 07-26-05, 05:03 PM
tmf2004
tmf2004's Avatar
thanks lexusk8 you have been a great help to me...
Tony
Old 05-04-06, 11:03 PM
Parke10
Parke10's Avatar
just reading this,had a question about the torque wrench thing, ive changed tons of brakes big and small of both disc and drum i dont think it goes for drum but for the disc u said dont use an impact gun to tighten them, thats all ive ever used and never had a problem and ive done about 3 ES's and about 10 camrys is it just a hit or miss thing with warping them and ive never had the bad luck or what?
Old 12-21-06, 11:01 AM
myztikal47
myztikal47's Avatar
Question for you guys, I bought some Akobono pads (the name is something like that, theyre supposed to be OEM) and they already have a metal shim on the ack of them, I tried to put the old metal shims ontop of them but they didnt quite fit.....the new metal shims are a bit smaller width wise compared to the old ones, so I don't need to re-use the old ones right? I can just apply some anti-squeal to the new metal shim and be good to go?
Old 12-21-06, 03:26 PM
Pheonix
Pheonix's Avatar
Cool
Akebone ProACT. Well it's a 2 part metal shim. One's a shim & one they call something else LoL!
Aslong as it's 2 thickenesses of metal you're fine. Otherwise you amy want to use the corrisponding old parts on the new pad.
Apply anti-squeal to every surface that touches each other. Including the outside that will make contact with the piston.
Rotors need about 1,000 miles of very easy driving to wear in (Says Brembo), Pads need 100-250 miles of very easy driving to wear in.
Old 04-30-07, 07:41 PM
vboy418
vboy418's Avatar
bump on this. This morning I read this thread and started on replacing my rotors and pads off of my 97 es300. Big problem for me was removing the 17mm bolts. I sprayed some WD-40 and waited for 30mins with no luck. I tired putting my weight into it with no luck and im not a small kid (210pds).
Any info guys??
Quick Reply: Brake pad and rotor change
