I seriously cannot find anything online. I just bought the car a couple months ago and the tires dry rotted out so I swapped them. Dude at the tire shop said i need rear hubs bad.. However on the list or things wrong with the car I remember one or the things just said rear bearings. I can find the bearings easy. Would I be okay just swapping out the bearings for now until I find the hubs?
If I'm reading the parts diagram correctly, the hub itself doesn't have a part number. The only way you could have even ordered an OEM hub is by ordering Part Number 42420-50020, SHAFT & DISC ASSEMBLY, REAR AXLE. Not having the OEM part number makes the search for even a NOS aftermarket hub more difficult.
What's the cause for calling the hub being bad? The tire dude might be referring to a bad bearing.
