turbo
Old 12-04-01, 04:15 PM
dj_kow
dj_kow's Avatar
Default turbo
does greddy make turbo kits for sc3's? wut r some good brands of turbos for sc3's?
Old 12-05-01, 06:38 AM
Bean
Bean's Avatar
nope Greeeeedy doesn't make kits for our cars
Their turbos are compatible with the manifolds of the various kit-makers for the SC300 cars
There's Toyomoto, Sound Performance, Powerhouse Racing, F-max, and several others
Toyomoto is touted to be the best, but they are also the most expensive... I'm sure one of the Toyomoto-kit owners will come put the phone number and website up here for you Toyomoto will work with you to customize your kit if the Stage I or Stage 1.5 is not enough for you
Sound Performance can strut their stuff as making the fastest kits, since their SP63 kit on a SupraTT ran 9s...
I'm not sure about PHR's kit, but they own the fastest unibody Supra in the world... makes 1200rwhp... they also do the SupraTT motor and transmission swap for a price...
F-max makes the affordable kit; albeit the manifold from what I've seen is kinda crappy Their turbo is the same brand as the Toyomoto and like Toyomoto they work with you to pick your components if the stock setup is not enough (like a bigger turbo, etc)... their $4800 kit also comes with a FMIC... it wouldn't be beyond craziness to buy the Toyomoto manifold, pick a turbo, then buy everything else from F-max; which is what i want to do...
Old 12-05-01, 07:01 AM
DIrEctQL
Chicago Lexus Club Moderator
DIrEctQL's Avatar
Default Re: turbo
SC300 has the same motor as the non-turbo version of the Supra. Actually, the SC300 is a coupe version of the Supra in case you don't know. A lot of the aftermarket parts for the Supra will fit the SC300. Keep that in mind. It also goes for the turbo kits, suspension, and wheels.
Old 12-05-01, 07:15 AM
dj_kow
dj_kow's Avatar
thx for the help every1
Old 12-05-01, 10:23 AM
Bean
Bean's Avatar
well everything in the turbokits EXCEPT for the manifold will work
different bolt pattern
Old 12-24-01, 12:43 PM
Rob_O
Rob_O's Avatar
Forgive me if I'm being dense (newbie-itis) but the bolt pattern at the cylinder head is different and the manifold for the 2JZ-GTE will not bolt up to the 2GZ-GE head?
I guess that would blow out any chance of doing the turbo conversion using a set of stock twins that have been relegated to the parts shelf from being upgraded
doh doh doh doh doh doh doh doh!
Rob_O
Old 12-25-01, 05:53 PM
Bean
Bean's Avatar
nope, but a GTE head WILL work on the GE block...
not sure what compression level it will give, you'd prolly need a different head gasket to lower it down to a SupraTT's 8.5:1
but no, the TT manifolds of any kind will not bolt up to a 2jZ-GE motor... you have to do the head swap
Old 12-25-01, 06:34 PM
Rob_O
Rob_O's Avatar
Sounds like an awful expensive and difficult way to save a few hundred bucks on the cost of the manifold. I think I will pass
EDIT: I just found/compared pics of the exhaust flange on both heads... Not even close to the same!
Rob_O
Old 12-26-01, 06:09 AM
SC300TURBO
SC300TURBO's Avatar
buy a toyomoto turbo kit and be happy for a long time..... Jeff
Old 12-26-01, 01:07 PM
Bean
Bean's Avatar
Yeah follow Jeff's advice.
toyomoto's manifold is better than OEM anyway
And thats saying something when its Toyota OEM that you're comparing too hehehe
Old 12-26-01, 03:44 PM
Rob_O
Rob_O's Avatar
You may be right... but I'm the kind of stubborn, machocistic bastard that likes to do things my own way so I think I'm gonna roll my own
I am not, however, too "smart" to follow the path others have blazed for me. I have found an incredible amount of knowledge on this board and do appreciate the number of quality posts. I have seen a lot of redundant questions so I'm trying to spend more time reading and less time typing to find the information I need and if I ask a question you think has been answered before I must have overlooked it.
For now, I'm going to go back to quietly lurking and hopefully someone will answer my remaining question here (question #2)
Again, thanks for the bandwidth
Rob_O
Old 12-27-01, 04:35 AM
SC300TURBO
SC300TURBO's Avatar
rob-o what do you mean by roll on your own..?...and what was the 2nd question you had..ill be happy to answer it....just ask...Jeff
Old 12-27-01, 08:05 AM
Rob_O
Rob_O's Avatar
Roll my own = take the Toyomoto manifold with a turbo of my choosing, weld up some customer intercooler pipes with fittings for the auxillary injectors, add some timing retard to keep things from getting too hot and smoke (mustangs, camaros or whatever else wants to play)
As for the other question, that had to do with the Supra rear diff. I had linked the "here" in my previous post to another thread, I've hilighted it so it'll be easier to follow
Rob_O
Old 12-27-01, 10:50 AM
SC300TURBO
SC300TURBO's Avatar
so your gonna butcher it huh...lol.....the auto tt rear will fit in a 5spd with modification to the drive shaft..i dont know exactly what and dont know if it will work on the auto>?
Old 12-27-01, 11:55 AM
Rob_O
Rob_O's Avatar
As long as I have my BFH within reach nothing is impossible
The post I read said I only need to change out the driveshaft flange to get the A/T Supra diff to bolt in. Sure wish someone could tell me why I would want to
Rob_O
Quick Reply: turbo
