Vivid Racing Review!!
Great thanks for the vids! Did it put up the same numbers as last time? I'm curious to see if the gains held since last time.
Ok here are the dyno sheets it shows an increase for sure not as much as they stated but still an increase its up to you all to decided if its worth it or not to get it based on these results. I will try to do another dyno in spring time to see if it still produces more or less than or even the same.
First run in normal mode with valve closed
Second run in sport + mode with valve open
Third run in normal mode with valve open
So you put how many miles on the car before the most recent dyno?
And the before dyno was 257whp and the after was 266whp? Sorry man, getting confused with trying to figure out what sheet is when and what numbers mean what on the sheets.
Can you post the HP/TQ numbers before and after tune, and exactly how many miles were driven between? Thanks!
I think this doesn't do anything guys. I think if he had dynoed his car again without it, he'll still get about the same HP/TQ numbers.
Well thanks for trying BB06!
If we compare the WCF corrected numbers, they are pretty much the same as before the flash, +/- a few hp. Can you post the graphs as well?
