Stroker Kit..
Old 04-11-02 | 05:22 PM
mjames08's Avatar
mjames08
Default Stroker Kit..
Here is what I received from the guy someone was talking about a stroker kit to:
"Mark -
A stroker kit for your Lexus SC400 is $2,099 plus a crankshaft. The kit
consists of a stroked crank, a set of forged pistons in your choice of bore
size and compression ratio, and a set of the Deves racing piston rings.
Delivery time is 6 to 8 weeks. when you get ready to do this give us a call.
- Carl at PAECO"
How does this sound? I would definately go to a 5.0.. I don't know anything about stroking an engine.. any thoughts? What would the cost of installation be on something like this? Should I port and polish the head while I'm at it? Pro's / Con's??
Mark
Old 04-11-02 | 06:46 PM
SupraCoup3's Avatar
SupraCoup3
wow sounds good, but wouldn't the ECU need SERIOUS updating?
Old 04-11-02 | 08:47 PM
the_ez_rhino's Avatar
the_ez_rhino
Dont know about the ecu being updated, but if it did, I bet Leo at weapon R would be all over it if you brought your car in. And when you bore a car dont you physically need to make the holes bigger? (or did that make no sense, my friend tried to explain the mechanics of boring and stroking and **** to me but it was a little over my head)
Jason
Old 04-11-02 | 08:51 PM
MadMaxSC400's Avatar
MadMaxSC400
I should try this out since I live near the WR shop. Got a phone number for these guys?
Old 04-11-02 | 08:55 PM
MadMaxSC400
In fact, if you're serious about this setup, I'll go ahead and order it, I just talked to Leo and he said he can tune it. I'll have my timing belt replaced at the same time, since my motor's getting up in mileage.
Old 04-11-02 | 10:10 PM
lex400sc's Avatar
lex400sc
Any ideas on performance gain, effect on mileage, or the optimal compression ratio for best 0-60 times? MadMax, did Leo give a price range on the ECU tuning?
the_ez_rhino, you are correct. Bore and stroke are just measurements: bore = diameter of cylinder, stroke = amount of up/down movement the pistons do.
Old 04-12-02 | 08:09 AM
mjames08's Avatar
mjames08
Default Weapon R
Tell Leo not to throw away the specs for your ECU, since I want to do the same thing Do you know of a palce that will install the Stroker Kit? Might as well have the head ported and polished too.. Email me @ mjames08@sprintspectrum for the phone #
Mark
Old 04-13-02 | 11:41 PM
Lex Luthor's Avatar
Lex Luthor
There are two heads, and if the price doesn't include the crank, then you're talking about $2100 for pistons and rings
Old 04-14-02 | 12:59 PM
mjames08's Avatar
mjames08
When he says "The price is $2099 plus a crankshaft" he means a core return...
Old 04-14-02 | 01:29 PM
Lex Luthor's Avatar
Lex Luthor
So it's a reground stock crank and pistons for $2100+ core? Should include the rods for that much, and IMO i'd rather see a nice aftermarket billet. If you can find out, what will the final displacement be, assuming we would bore the cylinders not much more than a cleanup?
Old 04-14-02 | 01:36 PM
mjames08's Avatar
mjames08
It is a custom job, so you can choose the displacement, etc..
Old 04-14-02 | 03:36 PM
Lex Luthor's Avatar
Lex Luthor
Hmm, I wonder if they can do something approaching 5000cc, like the C's kit. mjames08, thx for the info.
- Jon
Attached Thumbnails Stroker Kit..-soarer-v8-5-litre-stroker-kit-c-s-i-think-.jpg
Old 04-14-02 | 07:46 PM
sc400's Avatar
sc400
Hi MadMaxSC400,
I like your rims. Is your Lex lowered? If so what springs?
Old 04-14-02 | 11:28 PM
mjames08's Avatar
mjames08
- Jon
Didn't know C's had a kit.. Has anyone successfully imported any of C's stuff? How has the costs been?
Old 04-15-02 | 02:36 AM
MadMaxSC400
Originally posted by sc400
Hi MadMaxSC400,
Thanks, my car isn't lowered, it's just sitting that way because the stock suspension's pretty beat
