I promise I tried the search function
Got nowhere. Has anyone ever had blue-tooth added to our SC radio? I love stock and will go without music before I change out my stock unit. I have used several of Retroplays ideas, but didn't want to have to listen through the AM band due to noise. I have a '04 and really don't get it as many cheaper 2004 vehicles had it. Any help?
I added the VAIS Tech SL3B BT to have the ability to stream music using BT. Works great, but a little expensive. You have to pull your radio to unplug a harness and plug in their adapter harness. It's all plug n play so no cutting wires. There are several installation threads if you do a search. I find it's worth the money. The audio quality is great.
Look at this link to see what's involved with pulling the radio.
https://www.clublexus.com/forums/sc4...oem-radio.html
you can then choose your word and/or you can select the username.
i do it all the time and it works GREAT!
if you need more help, give me a shout.
Go to post 8
https://www.clublexus.com/forums/sc4...knowledge.html
and another
https://www.clublexus.com/forums/sc4...bluetooth.html
again, I used the advanced search and exactly what I was looking for...
and another
While the OEM radio is good the sound out of our pioneer avh-4200 neh is far superior.
Especially if you are playing a DVD,
different drive totally.
some are into high quality sound some are not.
speakers are jumping in the doors at medium volume.
BTW, I have the Pioneer AVH-X5700BHS and it sounds much better than the OEM radio.
Stereo
they are paper speaker cones so their life span is limited.
Not as worried about a future speaker replacement as the 4200 has an auto equalizer system that worked well when used
I have a 2002 and added a lot of aftermarket toys to my system including a bluetooth dongle which piggy backs off the VaisTech SL3U. I've really happy with my setup as well as the upgraded JL Audio system running off the ML amp. I have recently started using it with my wife's playlist that she created on SoundCloud. She adds great music and I can stream it anytime via the Arion/Eagletech Bluetooth Dongle which connects to my HTV One M9. Plus I can move forward/replay the track and take/make phonecalls plus responds to OK Google. Also, I have a hardwire connection for iPhones, but she can also connect via Bluetooth to the same dongle. Check the links below.
https://www.clublexus.com/forums/sc4...on-naviks.html
https://vimeo.com/user54620921
http://www.break.com/video/ugc/sc430-3037080
Alex818
08-02-13 07:34 PM
