Under dash panel removal
Shawn
I located the 10mm on the right side and the one under the parking brake release but couldn't find the remaining one that's still holding the left side in. Can you give me any more info as to where to look? Do you know if I need to drop the hood release handle as well?
Thanks,
George
Thanks,
George
There is another against the foot well wall nearest the engine, I believe. No, you shouldn't have to remove the hood release handle. Additionally, there is a wire harness holding the gas tank/trunk release panel button unit in place. You will have to unclip that. It's easy to do it by feel, or you can just push the button panel (towards the rear of the car) through the entire panel, and then disconnect it.
Found this diagram in the airbag replacement procedure which shows a bolt location on the left side which is what I think you're referring to.
http://www-odi.nhtsa.dot.gov/acms/cs...3V133-9856.pdf
3 10mm bolts, bottom forward edge right side, under parking brake handle the left of the two visible, the left one is behind the vertical trim piece between the dash and the door, it pops off.
2014IS250
01-29-14 10:30 AM
i3urton
10-07-07 08:35 PM
