Driver side mirror wont tilt down - Club Lexus Forums
Thread Tools Search this Thread
Old 06-25-16, 07:50 PM   #1
lbintab
lbintab's Avatar
Default Driver side mirror wont tilt down
I've had this issue for quite a while. on and off for the beginning of me owning the car and now pretty much all the time. The driver side mirror will not tilt down or up. Only side to side. Any ideas? The passenger side works fine and even tilts down when i reverse.
lbintab is offline   Reply With Quote
Old 06-25-16, 11:16 PM   #2
GmanSC
You might have a bad motor control. Might have to replace the mirror. You can find a used one in the junk yard or eBay .
GmanSC is offline   Reply With Quote
Old 06-26-16, 08:29 AM   #3
ShawnOk
ShawnOk's Avatar
Yeah sounds like a bad motor. Luckily, I have a spare driver's mirror with all working motors and worm gears. From what I've heard it's an easy swap to change the motors. Let me know, if you're interested.
ShawnOk is offline   Reply With Quote
Old 06-26-16, 08:43 AM   #4
JohnnyCake
JohnnyCake's Avatar
This is a common problem. The plastic gears get stripped. I once had a Lexus mechanic tell me that it is the worst designed unit on the entire car.
It is for this reason that I have the "tilt when in reverse" set to OFF -- less use the better. Also, take extreme caution when cleaning the mirror not to press hard enough that it moves. And that's not much pressure at all.
JohnnyCake is offline   Reply With Quote
Old 06-26-16, 03:11 PM   #5
Harold57
Quote:
That was my thought also. Seems like there were a couple of threads on replacing the gears or the mirrors back a few years ago.
Harold57 is offline   Reply With Quote
Old 06-26-16, 07:27 PM   #6
GmanSC
Johnny,
How do you turn off the tilt down?
Old 06-26-16, 08:32 PM   #7
JohnnyCake
JohnnyCake's Avatar
Quote:
Originally Posted by GmanSC View Post
Johnny,
On the switch that controls the mirrors, there is LEFT, RIGHT and CENTER. If you leave the control in CENTER, it will not tilt the mirrors during reverse.
Old 06-26-16, 11:50 PM   #8
GmanSC
Thanks Johnny. Learned something new today.
Old 07-01-16, 09:17 AM   #9
lbintab
lbintab's Avatar
Can the internal parts be replaced without changing the external plastics? I had the entire car painted a different color. I don't really want another mirror to have to be painted.
Old 07-01-16, 09:20 AM   #10
nc356
Before tearing in to a mirror, check the mirror control switch.
Symptoms match switch contact corrosion; easy fix too.
nc356 is offline   Reply With Quote
Old 07-01-16, 09:35 AM   #11
ShawnOk
ShawnOk's Avatar
Quote:
Yes, the individual internal parts can be swapped. I have completely torn down both sides... here's a post with pics to help illustrate.
http://www.clublexus.com/forums/sc43...n-signals.html
Old 07-01-16, 02:02 PM   #12
mandyfig
mandyfig's Avatar
The side mirror quitting to tilt has happened to me on several occasions and on different Lexus cars. In almost all instance, I just tug on the mirror either up or down (left to right sometimes) and it actually dislodges and would return to tilting.
Before you do anything, try to force it to go up or down, left or right and then try tilting it. Hope it works for you.
mandyfig is offline   Reply With Quote
Old 07-02-16, 06:35 PM   #13
texsexlex
texsexlex's Avatar
..this has worked for me also
texsexlex is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Side view mirror tilt in reverse DP03 GS - 4th Gen (2013-present) 4 10-18-16 06:03 PM
tilt side mirror jgarrido IS - 2nd Gen (2006-2013) 1 09-19-16 01:26 PM
Side mirrors tilt up SoKali-RX RX - 4th Gen (2016-present) 8 11-27-15 11:27 AM
NX Side-Mirror-Tilt in Reverse and Other Tricks cb80923 NX Models (2015-present) 4 12-18-14 04:37 AM
Mirrors don't tilt everytime I put my SC430 into reverse Max707 SC430 - 2nd Gen (2001-2010) 7 10-01-06 04:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
