Fog LED and DRL Light replacement
Old 06-28-16, 08:56 AM
Harold57
Harold57's Avatar
Originally Posted by StillLine
I would like to replace the OEM incandescent H3 fog lights with LEDs for a closer match between the fogs and LED DRLs.
StillLine
If they are truly to be used as fog lights, then keeping them yellow is better. Yellow lights will not reflect in the fog as bad as white lights will in foggy conditions making it easier to see.
Old 06-28-16, 11:31 AM
StillLine
StillLine's Avatar
Default You are correct.
Yep, that's right. If I were interested in the advantage afforded by the fogs whilst driving in the fog, I'd leave them alone. I'll switch to LEDs solely for aesthetic reasons.
Old 07-01-16, 02:18 AM
exbboy510
exbboy510's Avatar
Hey fellow sc owners quick question for the interior map light I have the led bulbs to replace the original but the led does not work for some reason any suggestions thanks
Old 07-01-16, 05:38 AM
Coleroad
Coleroad's Avatar
They have to be reversed polarity bulbs for the map lights.
Old 07-01-16, 09:04 AM
Harold57
Harold57's Avatar
There are some vendors that will supply the BA9 with a reversed polarity set up. (This is what I did.)
Another option is to get the panel kind of LED with a cable on it and you control the polarity by reversing the connector. The panel kind installs with adhesive.
Old 08-10-21, 01:36 PM
Noddy
8th Gear
Noddy's Avatar
Default COB Light
Originally Posted by 416tt
DRL:
i didnt need to take my bumper off for DRL, just had to take out the intake/filter box on one side..
any one of these kits will due with the decoder:
http://store.ijdmtoy.com/Lexus-Acura...Y&Search=Lexus
you can choose car model and it will tell you what setup you need, i think its R4 for all SC.
Attachment 389066
they have changed there bulbs and listings.. I have the kit from like 3 years ago...
1) and it came with the SMD bulbs under 1) which you dont want.. they flicker at a very high rate, i dont know how to explain but if you stare at them you can see there is a very stable constant flicker,
2) so i replaced my bulbs with cob ones below and there solid, brighter..
1)smd dont get these
Attachment 389068
2)COB ones i replaced mine with these and they are great.. but ijdm now has newer bulbs, they may be good.
Attachment 389069
as for fog lights:
I bought these but there are 2 issues.. one will be with all conversions kits and that you wont get to close the cap as these bulbs have long back ends.. but should be ok if you have a good seal.. I mean i had them on my GX which has open slits.. took it through all kinds of weather.. car washes... bulbs are still great after 3 years..
second issue was specific to the bulb i bought which was
Attachment 389070
get led conversion kit with small back like this:
Attachment 389071
Led conversion kits are very bright.. i used them for fogs on my gx.. ill post a pic soon.
Question: first time on this site and not certain whether my question is being requested correctly. Where can I purchase the bulbs shown in the #2 picture? Appreciate your response. Thanks
Old 08-10-21, 03:11 PM
Noddy
8th Gear
Noddy's Avatar
Please advise where I can purchase this bulb. Thank you in advance.
levinsoy
01-08-17 11:49 AM
DewHawk
RX - 1st Gen (1999-2003)
05-14-15 09:57 AM
zen
IS F (2008-2014)
05-04-15 01:02 PM
mrxthuan
08-03-09 06:57 PM
Quick Reply: Fog LED and DRL Light replacement
