5spd transmission drain & refill
Old 05-27-16, 06:52 AM
mrblister
mrblister's Avatar
Originally Posted by Bgw70
Why would you do it this way?
I just unbolted the drain plug!
Do you have a drainplug?
What kind of car do you have?
__________________
I have a 2005 sc430 and no dip stick. Not sure if prior years have a dipstick anyone know
Old 05-27-16, 07:04 AM
Coleroad
Coleroad's Avatar
Yes the earlier sc430's still have a dip stick for the transmission. You can see it in the picture with the brown/red top.
Old 05-27-16, 07:08 AM
mrblister
mrblister's Avatar
The picture is small and I cant see the dipstick.
Old 05-27-16, 07:12 AM
Coleroad
Coleroad's Avatar
If you click on it, it should go full size.
Old 05-27-16, 07:17 AM
Bgw70
Bgw70's Avatar
It's just below the number three spark plug coil, kind of Burnt orange or brown
Old 05-27-16, 07:18 AM
mrblister
mrblister's Avatar
I did and all I see is engine oil dipstick engine oil fill I see the green air cond valve but I don't see any trans dipstick
Old 05-27-16, 07:30 AM
Coleroad
Coleroad's Avatar
Here is a better picture.
Old 05-27-16, 07:35 AM
mrblister
mrblister's Avatar
Now I can clearly see it. Thank you I am guessing that it was discontinued in 2004 forward ?
Old 05-27-16, 07:37 AM
FlopTop04
FlopTop04's Avatar
My 2004 has the 5 speed transmission and the dip stick. Thought it was the 6 speed transmissions that did not have a dip stick.
Old 05-27-16, 07:38 AM
Coleroad
Coleroad's Avatar
Yes 04 was the last year with a transmission dipstick.
Old 05-27-16, 07:44 AM
mrblister
mrblister's Avatar
My 05 is also a 5 speed I don't know how it differs from the 2004 5 speed but for sure I have no dipstick
Old 05-27-16, 08:12 AM
Coleroad
Coleroad's Avatar
Through 05 the sc430 used the A650E transmission. The only difference I know of is the removal of the dipstick tube. In 06 they went to the A761E transmission. I can't find any part differences between 02-04 and the 05 transmission.
Old 05-27-16, 11:23 AM
Bgw70
Bgw70's Avatar
And one more...dang Cole, my engine is filthy compared to yours! Better get the toothbrush out this weekend! ;-)
Old 05-27-16, 11:43 AM
Coleroad
Coleroad's Avatar
It's just as clean under all the plastic covers too. I pull the wheels once a month and clean the wheel well and suspension bits. I pull the grill when I wash the engine bay so I can clean between the bumper and the ac condenser. I have trouble stopping. If I see something else dirty I just have to clean it too. I've tried just doing a good job but not worry about the little things. I end up going out the next day and do the rest because I can't quit obsessing over it. As my son says to me darn OCD.
Old 05-31-16, 09:01 AM
lexixel
lexixel's Avatar
Just another update:
Finally, got the fluid changed back to Type 4.
I noticed a quite obvious difference in torque converter behaviour: with the WS, the torque converter clutch would disengage immediately once the foot is off throttle (almost any speed). with T4, it's normal.
I'd like to ask a question:
Now, the level is exactly between min and max. Should I add some to bring the level to max (need to buy)? What's the difference between min and max? Is it 1/2 or 1/4 litre (quart)?
Thanks in advance!
Quick Reply: 5spd transmission drain & refill
