Putting the HT up/down when out of Park
If that doesn't work, the solution would be a bit more complicated.
Retro something that I might be interested in & being along the same lines. I haven't done the quarter window mod,but there is a procedure that allows you to let the quarter windows up with the top down, but you get the warning buzzer / flashing light. It's been along time since I've done it, so don't remember the sequence off the top of my head,but I would like to be able to roll the quarters up & not have the warning buzzer / light. I'm pretty sure someone will chime in tomorrow with the procedure, before I get back online & hopefully it will shed some light on this matter. There may be a way to disarm the warning buzzer using the OBD scanner/tool, but not sure. I've been putting off doing the mod, but may go ahead & jump into it, but have come to realize with the top down & the quarters up, it's a lot less wind & much quieter
I did the Quarter Window mod with help from Bimmer. The wiring diagram was drawn by scyul and props to him. Anyway if anyone wants my diy of how to do it just ask. It looks complicated and to be honest if it wasn't for bimmer encouraging me I probably would not have done it. Once you get your head round all the wires its pretty easy. Most of the work can be done on the bench.
After the install I added another switch to cut the power to the passenger side (you have to make sure that it is in position for both to operate before opening or closing the roof or it will lock out) so that I could operate the drivers side or both seperately as I prefer to be able to open just the drivers side with the side window most of the time.
Cheers
Steve
I am a DIY guy for sure, but the roll up/down modules are so inexpensive, that I would really recommend just buying one to save the hassle.
Manual showing wiring diagram:
http://www.megatronixusa.com/manuals/WT4Manual.pdf
What's needed is a 4 window module (if you want individual window control) or you could also use two modules like the Directed 529T. If you don't want them independent, you could get away with just one up/down module.
Amazon.com: Megatronix - WT4 - 4 Window Roll Up Or 2 Window Up/Down Module With Automatic Temperature And Remote Manual Ventilation: Automotive
What would be really neat is to find a solution that's similar to the way the LuxLink QuarterWindow mod works to roll the rear windows up/down. From my understanding, you can triple tap (up or down) either the driver window or passenger window from the driver side control, and that will roll up/down the rear quarter windows. Retro, think you can find a way to get rig something like that up?
BTW Retro, this is the mod I was discussing with you in regard to me making the trip up to you so we can do it together. I do the tear down on both our cars to expose all the hardware, you go HAM on the tech and wiring!
Also, in regard to the double tap of the top drop button on the A/C control. The LuxLink Gen3 had this option. It would be cool to find a way to get it to have a similar function as the LuxLink Gen3 is not being produced. (I have the LuxLink Gen2 without this feature and would love to add it).
...appreciate everyone's info & I'll probably jump on it in the next few months. I do have the original write up & the diagram that you posted Wil44......so the next question that comes to mind, if I used one of the modules that Retro posted, does that make the wiring more simple or is it the same procedure,just using a different unit? As much as I've been into my audio/nav system, I don't know why this one makes me hesitant to jump into...lol
Tex, in either case, all you are doing is wiring the module (or relays above) in between the ECU and the motors.
Either one, simply disconnects the connection from the ECU and applies power to the motors manually.
It looks more complicated than it is. If I could find the connectors, I could make harnesses and it would be not be much more difficult than just plugging things in.
Shawn, anything can be done. That would require another little module to be designed to sense the triple taps, but that's not difficult.
I found a source where I can order connector housings, but I need to figure out how to tell the part numbers of the different terminals.
I'll be getting into this mod soon, Shawn wants it too. So, I will let you know when I get there. We were originally talking about using the homelink buttons, but I like what Shawn said about the LuxLink works and I think I will go that route. So that means making up a little box to interface with the window buttons.
Scott610
IS F (2008-2014)
05-24-16 07:16 AM
