rear car shake
Old 09-16-15, 08:45 PM
LEXZILLA
LEXZILLA's Avatar
Default rear car shake
i have a 03sc430 with 144,000 on the clock and the rear of the car shakes around 60-70 mph
ive had all tires road forced balanced nothing wrong with tires rides fine until i get to 60 mph
i heard a click noise once when the car was parked in a driveway on an angle
hey guys
by the way the search function revealed nothing about rear end shake
so dont flame me
thanks for any advice in advance
lex
Old 09-17-15, 05:13 AM
LEXZILLA
LEXZILLA's Avatar
more info:
wheels are verde madonna the tires are 255/35/20 all road force balance and zeroed out
what should i have checked?
i really need your help guys!!!!
Old 09-17-15, 05:36 AM
Bgw70
Bgw70's Avatar
This may be a silly question but do you have the original wheels with tires or any wheels with tires to use for testing purposes?
is it possible to move the fronts to rear and rears to front?
Have you always had this problem, if not when did it start, slowly or all at once?
Old 09-17-15, 07:41 AM
LEXZILLA
LEXZILLA's Avatar
The car rode fine and then the shake started up front
I moved the tire I thought was shaking to the rear had it road force balanced it zeroed out
I just had all of the tires checked out all of them checked out fine
But I still have that vibration in the rear
Old 09-17-15, 10:18 AM
LEXZILLA
LEXZILLA's Avatar
Hey guys please!!!!
Old 09-17-15, 10:38 AM
kjcole
kjcole's Avatar
check alignment. I know..sounds crazy...
Also, I assume these wheels use hub adapters since few aftermarket wheels are made specifically for Lexus. More than a few people found their shaking goes away with the stock wheels
Also, be very precise with the pattern you use to torque the lug nuts, as well as applying the same torque to all the lugs on a wheel. Don't overtorque.
Old 09-17-15, 12:17 PM
bb430
bb430's Avatar
I second on the rim hubs.
Old 09-17-15, 01:00 PM
Bgw70
Bgw70's Avatar
If the problem was up front and you moved one wheel to the rear and now the problem is in the rear (so to speak) it appears to be that wheel.
If it were me, I would move the one wheel back to the front to see if the problem follows.
If it does, you have a bad wheel...
Old 09-17-15, 07:09 PM
Harold57
Harold57's Avatar
BTW, the click you heard was probably the brakes. (The noise doesn't really indicate a problem, just an annoyance.) There are a couple of threads on rectifying the noise. (Look for "brake clunk", there's probably other words that work also.)
Old 09-18-15, 09:58 AM
ShawnOk
ShawnOk's Avatar
I also believe this to be either a bent rim/wheel or lack of hubcentric rings on the aftermarket rims. Please check those two recommendations out and let us know what you come up with. Good luck!
Old 09-18-15, 10:20 AM
LEXZILLA
LEXZILLA's Avatar
Update......
One of my wheel was slightly bent
But.... After having my wheel road forced balanced ( high tech)I went to another shop (old school) found a old guy with a manual balancing machine (very low tech),balanced my wheels and the shake is minimal
So much for high tech!!!!!
Old 09-18-15, 10:57 AM
LEXZILLA
LEXZILLA's Avatar
The miracle worker
Old 09-18-15, 11:15 AM
Harold57
Harold57's Avatar
Cool, but I'd still be concerned about tire wear with a bent wheel.
Old 09-20-15, 05:48 AM
rudyH
rudyH's Avatar
Update......
So you put the bent wheel back on the car?
Old 09-20-15, 06:55 AM
LEXZILLA
LEXZILLA's Avatar
Yeah I put the wheel back on the car till I can get it repaired
Quick Reply: rear car shake
