Still getting some codes after accident.. P0430 & p0125
If you are only showing pre O2s then yes, I would agree the bank2 pre O2 does not seem to be functioning correctly.
I would also agree that your temp sensor is functioning correctly.
Since you did find vacuum lines disconnected, I would reset the ECM and wait to see if any new codes appear. Also, since this is a new to you engine, I would change out the PCV valve. They are less than $10
Just discovered that my dashcomand app wasn't configured for post cat O2 sensors, and I just made the change and will do the data logging on my way home and report back tomorrow with post cat voltage. I just bought a new pcv valve last night and reset the ecu. Fingers crossed!!
As Helo said, there are some good videos.
Here is a thread I created when I had a P0430 code on my Trans Am. It has a good video and I understand the code much better now.
http://ls1tech.com/forums/generation...430-codes.html
Good tip on the Pre-Post output data. That's the only way they detect an NG condition that flags the ECU to trip a CEL.
My p0125 finally went away after I changed radiator and did a full ecu reset. Now I found 0 voltage on one 02 sensor so I will replace that and hope the p0430 goes away too!!
Success ... I think
Reconnected O2 sensor wire and now reading voltage. Hopefully this will make electrical gremlins go away
Greg, I assume you have your dashcommand linked with an obd2 device. If so, all you do is hit "start data logging" and then with finished send to your email in a csv file. Then open in MS excel and select the data area and insert a pivot table. Let me know if you need help! You can track just about anything, and if you could probably even do some statistical correlations (e.g., relationship between air intake temp and engine power)
Ohhh got it. I thought you did it in Dash Commander. I can do that in Excel. Thanks.
Does your's show some incomplete monitors?
skye2388
12-08-13 07:22 PM
