Dome/Trunk Light Fuse?? - Club Lexus Forums
Thread Tools Search this Thread
Old 07-14-14, 09:12 AM   #1
djsurfer
Default Dome/Trunk Light Fuse??
Greetings, was doing the last of my LED conversion on MAP lights and the cheap LED ground point gave out while pressing in to twist and fit the bulb so the Positivve/Negative made contact and blew the Map lights fuse, also noticed lights inside trunk don't turn on which means its in the same circuit. Spent a long time trying to find the fuse to it but no luck, looked in the hood fuse box, driver side fusebox, and trunk fusebox but couldn't locate it, nothing that says MAP or DOME or remotely close as Im used to. Anyone have an idea of which fuse it is and in which fusebox its located? I would like to have working interior lights again. Thanks!!!!
djsurfer is offline   Reply With Quote
Old 07-14-14, 09:18 AM   #2
mrblister
mrblister's Avatar
Quote:
Look in the passengers side there is a fuse box there behind the front lower kick panel same on drivers side
mrblister is offline   Reply With Quote
Old 07-14-14, 09:22 AM   #3
djsurfer
Just saw it, and found it! Thanks!!! Havent had a car that had 4 separate fuse boxes and/or a fuse box on the passenger side. Just bought my SC a few weeks ago and still trying to get used to this newer Lexus after (and still) owning a 92 LS. Hope this helps other noobs aswell. Thanks again MrBlister!!
Thread Thread Starter Forum Replies Last Post
Interior light mod? heybro GS - 2nd Gen (1998-2005) 6 03-09-17 10:38 PM
One Brake Light out, Bulb's Fine, Fuse is Fine - Lexus 2001 RX300 Darrenbret RX - 1st Gen (1999-2003) 9 06-21-16 03:17 AM
Rewiring your fogs in 95 LS400 spinout180 LS - 1st and 2nd Gen (1990-2000) 57 01-11-16 01:47 PM
Interior lights/dome fuse blowing repeatedly rwheelz LX - 1st and 2nd Gen (1997-2007) 7 07-15-15 11:43 AM
LS400 Fusebox jmblimo LS - 1st and 2nd Gen (1990-2000) 3 08-17-07 12:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
  • Ask a Question
    Get answers from community experts
What's your question?
Send
