Brembo Big Brake Kit SC430 Rear
#32
Yes they do LXurious. I know they're pricy but I want it done to my taste. I work hard so that I can enjoy the things I like. I looked at Rotora and StopTech and compared them to Brembo, my choice was made very easily hands down. I must add my new brakes stop the car much better than the OEM brakes. No squeak in at all, just a lot of brake dust which equates to more frequent cleaning. 😁
#33
Rollaboy, I'm there with you! I searched for days on the threads at Club Lexus and I wasn't able to find the information. Now that I have shared the I have shared the information I'm sure others will benefit. My rear rotor demensions can be cross referenced with the Brembo master brake kit list. Good luck with your projects and thanks.
#37
Ironhart, here is the part number for the front four piston calipers and two piece rotors (1B1.8014A) that fit a Lexus 93+ GS300 400/430 front. The rear calipers are a special order that have been discontinued for the SC430. You won't find them listed on any website. You need to call local dealer for Brembo of North America where you will be referred, with 100% payment that's is non-refundable for the rear calipers and rotors. I suggest you get the year of the Dodge Charger and compare the specs that s/b listed on the web under Brembo's charts. Here is a screen shot of the specs for the front calipers.
#38
I'd like to revive this thread cos I've got the same calipers/drums as Darthsid but I'm trying to track down the part numbers for the carriers to bolt them up to a gs300.
Has anyone tracked down the part numbers for the carriers or did you ever write down the part number from the carriers that came with your kit Darthsid?
I'm considering machining but before I do that I wanna try and track down the original part because I know it existed
Cheers
Alex
Cheers
Alex
#39
Well, I took the other route and upgraded the front and rear with a StopTech 4-piston balanced big brake kit. What can I say, it is a difference like night and day. I love every corner that is ahead.
StopTech ST-40 Big Brake Kit
front
rear
front
rear
