Tire wear questions
Old 11-14-13, 11:06 AM
iolmaster
iolmaster's Avatar
Originally Posted by akdash1
Yes, the information above was incorrect.
"Zero camber will result in more even tire wear over time, but may rob performance during cornering. Ultimately, optimal camber will depend upon your driving style and conditions the vehicle is being driven in."
http://yospeed.com/wheel-alignment-e...er-caster-toe/
Either akdash1 misunderstands what we are saying or he doesn't express his position correctly. What was posted above is absolutely correct.
Old 11-15-13, 02:12 PM
akdash1
akdash1's Avatar
I misunderstood. I just found it surprising that the closest to neutral that the adjusters allow is still so aggressive. That, combined with the fact that I didn't read it very carefully, I thought you may have got some numbers mixed up.
Old 11-16-13, 02:56 AM
Anion
Anion's Avatar
I had this problem when I had my stockies on. The tire wear was uneven on the inner barrel. So the goal to get rid of this is changing camber to -0.9 to the front or rear? I'm confuse on that part
Old 11-16-13, 03:27 PM
akdash1
akdash1's Avatar
If the wear occurs on the inside edge of the tires, the problem is a result of having any toe angle. Reducing the camber will reduce toe wear , but if won't fix the problem. Best to go with a neutral toe.
Old 09-15-16, 07:33 AM
nova20
3rd Gear
nova20's Avatar
Default how to fix SC430 tire issue
Seen the messages. How do I fix the excessive tire wear on my 2005 sc430?
1. can the negative camber be removed? If yes, how? set it to neutral, positive or less negative? I am a regular driver - not a racer.
2. if the negative camber cannot be adjusted: what tire brand and specs to get? I now have Dunlop run flats p245/40rf18 93v.
thanks,
shortbus19
Wheels, Tires & Brakes Forum
19
11-20-19 04:03 AM
uncandid
07-03-12 03:16 PM
Meraki Autoworks
IS F (2008-2014)
02-11-12 10:17 PM
RocketGuy3
Suspension and Brakes
24
06-13-10 01:14 PM
vbspunger
04-21-09 06:02 AM
Quick Reply: Tire wear questions
