2002 AC Climate Control Unit
...ok guys need your expert help....I need to purchase an a/c climate control unit. I was taking out my nav screen & broke the climate control unit. I started searching ebay for them, but see some listed without electro multi vision & some listed with...so my question, what is the difference ??? Looking at the pics, they seem to be the same,but I know there has to be a difference. I want to make sure I buy the right thing & it's plug & play. Also, do all the units control the top & nav functions or could that be the difference ???...thanx in advance
There were a handful of 2002 SC430's made WITHOUT Nav. From 2003 on, it was standard equipment.
So, there might be some 2002 Climate Control modules out there without the Nav controls across the top.
But, I would imagine those to be much harder to find than the climate control modules WITH the Nav controls.
lol...I had an issue with the nav door not closing and after reading a previous thread of a member experiencing the same thing, I was attempting to fix it. In my search for a new unit, I found out something that I previously didn't know.I was under the impression that having a system equipped with multi electro vision,meant your climate control system panel had the buttons/controls for the nav system located on the unit......that's why I asked the original question( for this thread),but I found out from Sewell that wasn't correct..If your vehicle IS equipped with the multi electro vision system, you can adjust your radio,a/c & other functions directly from the nav screen, as if it was a touch screen monitor.....so does anyone here have this capability ???
Tex is not making much sense.
From what little I know from driving an SC430 since 2001, his recent post suggests the following:
When he talks of the "multi electro vision" our eyes glaze over - this is a recently coined term (2010 or so, although the technology pre-existed the use of the very low informational term) to designate a system in which the touch screen has menus to control not only the NAV but also the heat/AC and often the radio as well. The SC has never had this. The top level NAV buttons are on the dash in a row under the screen - some control the door and the tilt, others call up the menu and the destination screens.
The screen in the SC is a touch screen monitor, but the heat, the AC and the radio are only controlled from their own set of buttons and *****, not from this screen.
So the answer to the question "does anyone here [the SC430 forum] have this [multi electro vision] capability" is no, we do not.
As far as I know.
I may be wrong.
As far as I know.
I may be wrong.
Tex, would you be willing to sell just the display from your old broken one (or is this what broke?) My climate control works fine, but a few of the segments on some numbers quit working, and I'd like to replace just the display.
As far as I know.
I may be wrong.
As far as I know.
I may be wrong.
momic
05-25-20 02:34 PM
