$1315.00$ for 60K Mile Service? Good Price????
Old 02-19-08, 05:23 PM
rclab1
rclab1's Avatar
Default $1315.00$ for 60K Mile Service? Good Price????
Hello, I just went in for my 60K mile Service and I got this quote ($1315.00 with tax) for the following to be done. Please chime in if this is a ok deal or not?
Replace Spark Plugs NGK Iridium
Replace engine Timing Belt
Replace Cabin Air Filter
Replace Engine Air Filter
Replace Valve cover Gaskets
Inspect and adjust valve clearance
Replace Brake Fluid
Replace Engine Coolant
Replace Transmission Fluid
Replace Differential Fluid
Replace Engine Drive Belts
Retorque driveShaft flange bolts
and
Inspect the following:
ball jts. and dust covers
body as per manual and stamp
brake/lines/hoses
driveshaft boots
exhaust system and mountings
fuel system components and vent system
rack and pinion assembly
steering Linkages and boots
nuts and bolts on body and chassis
I omitted Oil/Filter change and Rotate/Balance Tires because
I will do these two services next month.
Old 02-19-08, 08:19 PM
TLW
TLW's Avatar
Do you have any mechanical exp at all?
Old 02-19-08, 08:28 PM
Lexiss_sc430
Lexiss_sc430's Avatar
I personally think thats way to high, but then again I never take my cars to the dealer.
Would you be comfortable taking your car to a reputable mechanic?
What I usually do is buy my own OEM parts then give it to my mechanic to replace.
you could get everything you have mentioned above for $600 max.
Old 02-19-08, 08:43 PM
norman52
norman52's Avatar
I thought the timing belt was at the 90K miles service? Am i wrong?
Old 02-19-08, 08:46 PM
TLW
TLW's Avatar
pretty sure its 90k also
Old 02-19-08, 08:50 PM
TLW
TLW's Avatar
https://www.clublexus.com/forums/sho...47&postcount=6
Old 02-20-08, 12:26 AM
mrogers402
mrogers402's Avatar
I paid about 800 for my 60k service at the Oakland, CA dealer, 1300 seems really high
Old 02-20-08, 03:12 AM
rclab1
rclab1's Avatar
thanks for the reply everyone....I double checked everything and I found out that the 60K mile service that everyone is mentioning does not include
Spark Plug Change and Timing Belt Changes. These two services alone are equal to or way over that $600.00 price for a NORMAL 60K Mile Service.
So I think Spark Plug Change and a Timing Belt Change plus including everything in the 60K Mile Service for $1300 is a good deal.
I also checked that the 60K mile service does not include Differential fluid change.....and the price they gave me includes it.
anyone.......?
Old 02-20-08, 04:05 AM
LeslieRC
LeslieRC's Avatar
I didn't keep either of my SC430s that long (60K mi.) but, for what it's worth, I did change the timing belt on my SC400 when I owned that car and that service cost me $750 at the time. So, I would agree that with the timing belt change, $1300 seems to be in the ball park. My question, however, is whether the "normal" 60K mi. service should include the timing belt change.
Old 02-20-08, 07:17 AM
bubblerboy
bubblerboy's Avatar
I owned a 1992 SC 400 and the timing belt was changed at 60,000. I would think the SC 430 would be the same. I sold my Lexus car as it approached 120,000 because it was going to cost me $2000 for the 120,000 mile service plus the car needed tires and likely brakes. It was going to run me just short of $4000 to get the car into shape. Time to walk away. JEH
Old 02-20-08, 07:25 AM
rogers2
rogers2's Avatar
Replace Brake Fluid
and
brake/lines/hoses
driveshaft boots
Please verify that price again with the dealer. I doubt they're going to change your timing belt and service your spark plugs for 1300.
Old 02-20-08, 07:29 AM
gsrthomas
gsrthomas's Avatar
Why replace valve cover gaskets if its not leaking?
Who checks valve clearance on modern cars today?
I highly doubt that would even do this.
I do ths on my Honda and Yamaha dirt bikes not a 50k car!
Old 02-20-08, 09:46 AM
rclab1
rclab1's Avatar
YES, I double checked again with the dealer, it is a 60K Mile Service PLUS the Spark Plug Change and Timing Belt for $1315.00 with tax.
Spark Plug Change and Timing Belt LABOR hrs alone are highly priced, so I think I got a great deal.
Old 02-20-08, 10:26 AM
CenterIsl
CenterIsl's Avatar
Timing belt and water pump (including related items like front crank shaft seal and thermostat) are on a 90K or 6 year service schedule
I believe that the 60K service is simply the 2nd occurrence of the 30K service.
Old 02-20-08, 10:43 AM
audi2nr
audi2nr's Avatar
i think you got a decent deal from a dealer, if it included everything posted, how old is the car, usually if the car is older but still is under the mileage for a t-belt they do it because of age, same with serpentine or v-belts.
Quick Reply: $1315.00$ for 60K Mile Service? Good Price????
