SC430 Master Window Switch DIY
Old 02-25-13, 12:31 PM
Studie
Studie's Avatar
Default SC430 Master Window Switch DIY
Have an issue on an earlier model car.
2003 SC430.
Anyone have a diy for this piece?
Is it easy to get at? Last but not least, is my only option to replace the darn thing?
Thanks in advance
Old 02-25-13, 02:41 PM
mrblister
mrblister's Avatar
What is the issue sypmtoms. Sounds odd that the drivers side master switch has failed. Need more inforfmation as what is actually not working.!!
Old 02-25-13, 11:35 PM
Studie
Studie's Avatar
it's working, except intermittent. Sometimes it works, sometimes it doesn't.
Cleaned the contacts with wd-40 it seems to have fixed it a little bit but then it stops working again after a week.
Order the parts on eBay. Hoping it will arrive soon.
Old 02-26-13, 06:47 AM
mrblister
mrblister's Avatar
Default master switch
You have not answered my question. What switch is working do you mean all of the door switchs are intermittent door lock, windows , window lock out. window one click up and down ?? If all are affected then it sound odd that everything has failed . If it is one switch then check for a loose wire on the connector . Contact cleaner is different from wd 40. I think wd 40 is really not so much for electric contact cleaning
Old 03-10-13, 04:13 AM
Studie
Studie's Avatar
the driver side only, that was the problem...
I bought a new switch, any DIY how to replace it?
Old 03-10-13, 02:35 PM
mrblister
mrblister's Avatar
Default window
I am at a total loss since I still do not know what you mean. i know you said the drivers side .Does this mean that none of the switches in the master control are not working ?? If that is the case I would suspect another failure other then the switch.
Old 03-10-13, 06:05 PM
FlopTop04
FlopTop04's Avatar
Like MrBlister, I'm not sure exactly what you are asking for, but here are some links that might be helpful.
Here is a link to a YouTube SC430 Speaker repair video :
At time mark 4:14 it shows the removal of the drivers door window / locks control switch assy.
Here is a link to another to a SC430 Speaker install : https://www.clublexus.com/forums/lex...all-sc430.html While it is the passenger door, the top three pictures show the switch panel removal.
The leather is very thin in this area, so use caution when releasing / removing the control panel. There is only one connector to disconnect.
johnross
02-26-18 11:35 AM
05ls430518
02-26-18 08:40 AM
karthick
04-09-14 06:11 PM
GSteg
07-06-10 10:41 PM
wantalexus
RX - 1st Gen (1999-2003)
10-26-05 11:31 AM
Quick Reply: SC430 Master Window Switch DIY
