lexus logo projector puddle light
Old 04-10-13, 03:55 PM
  #61
Turboo
Turboo's Avatar
Originally Posted by ShawnOk
Looking nice, Turboo! Do you have any pics of the projected image on the ground? Is the height acceptable for a clear image? Thanks.
Here r the pics..by the way it is much more clearer in reality than may camera photos
I hope the rainbow circle is clear!!
Turboo is offline
Old 04-10-13, 03:58 PM
  #62
bacardi11
bacardi11's Avatar
mrblister
you did a nice job, looks cool.
bacardi11 is offline
Old 04-10-13, 05:46 PM
  #63
mandyfig
mandyfig's Avatar
Originally Posted by Turboo
I used the drill saw included in the projector box. Fix the saw on a drill machine ... hold the light cover with one hand after saperating the light cover from the light assembly...and drill it.
First cut was good but too much tight..so I just drill again with little more force on corners. Maybe if I used something to hold the cover while drillig it would be safer and better from the first time.
Thanks I think I got the idea.
mandyfig is offline
Old 04-11-13, 04:49 AM
  #64
harleydjce
harleydjce's Avatar
Originally Posted by texsexlex
...hey Bon thats a good look !!!
Nice work but I struggle with the projection having both the Lexus logo and the name. Either one or the other but not both but that's just me.
harleydjce is offline
Old 04-11-13, 05:53 AM
  #65
Bon
Bon's Avatar
Some of the ebay sellers have a tag line that says they will make you what you want if you email them. That could get interesting. How long will it be before we have to look at virtual bull testes hanging from their truck doors?
Bon is offline
Old 04-11-13, 09:03 AM
  #66
mandyfig
mandyfig's Avatar
I am like you, hence in my case I ordered the plain White. But to each his/her own I say.
mandyfig is offline
Old 07-20-15, 12:55 PM
  #67
photalian
photalian's Avatar
Sorry to bump such an ancient thread, but we may have a more built-in option now, replacing the red plastic light in the bottom of the door with something like these
http://www.aliexpress.com/item/2X-Lo...234725145.html
They range online from $10-20 if you look hard enough. Has anyone verified that they actually fit properly in SC430 doors???
Some of the listings say they fit in the SC430, others don't list them as fitting. They all look identical, so I don't want to order them before verifying.
photalian is offline
Old 07-20-15, 01:21 PM
  #68
ShawnOk
ShawnOk's Avatar
I have some that are identical, but from a site called WindFireAuto. Much cheaper too.They fit properly, but with time and the heat from the lamp the logo chip does discolor and thus an additional way for them to make money. You can order a few extra logo chips and save yourself some headache later. You can also have them create a custom chip too! Pretty neat.
http://www.windfireauto.com/
Ps. if you sign up for their mailing list you will get a huge discount on your first purchase.
ShawnOk is offline
Old 07-20-15, 03:05 PM
  #69
mandyfig
mandyfig's Avatar
This is awesome! No need for drilling and retrofitting! Very cool.
I purchased mine (all white) for $25 per set of 2 but had to do all of the drilling, etc. I installed them on the doors and one on the rear.
Did I ever tell you that the Lexus Dealership gave me a huge compliment about my puddle lights (when I brought the car in for the Air bag recall)? Everybody in the dealership were in awe. My service person called the rest of the guys to show my puddle lights. Reminds me I still have to get my airbag done.
I forget them until a friend would comment “hey that’s neat!”
mandyfig is offline
Old 07-20-15, 03:18 PM
  #70
Bgw70
Bgw70's Avatar
Shawn, are these lights a direct plug and play door light replacement?
Bgw70 is offline
Old 07-20-15, 03:30 PM
  #71
mandyfig
mandyfig's Avatar
Looks like it is a direct fit.
I had to drill mine directly into the door (the puddle light projector).
I still have my regular LED door lights (I disabled it fearing the logo will not be as noticeable but it found out it was still OK) which turn on when I open the door-PLUS the Lexus Logo puddle light.
Then I have the one in the rear which is so cool. Also turns off after like in 15 seconds, auto-off.
mandyfig is offline
Old 07-20-15, 03:33 PM
  #72
mandyfig
mandyfig's Avatar
It also appears that Lexus has been using the same door light fixture across their lines. You will notice that the same piece will fit a lot of cars (RX, IS, etc).
mandyfig is offline
addcar (09-16-21)
  #73
ShawnOk
ShawnOk's Avatar
Yup these were plug and play. No need to drill or rewire. MandyFig, I believe you went with a better model that required more clearance and therefore your resultant drilling. These, that I've linked above, were an easy snap in place and good to go. I will say that you will have to adjust the chip to make sure you get it in logo the direction you want but it's easy enough to do with a small screwedriver or tweezers. I'm happy with mine, except that i need to get new chips about once a year. That's the bummer.
One additional note, these do not auto shut off after 15 seconds as MandyFig's therefore increased heat and lessens the life of the logo chip. Just something to keep in mind too.
ShawnOk is offline
Old 07-20-15, 03:37 PM
  #74
Bgw70
Bgw70's Avatar
That sounds really cool Mandy! I guess the rear projector would be a special install and not a direct replacement. I was hoping they had a replacement license plate light with the logo projector.
Bgw70 is offline
Old 07-20-15, 03:54 PM
  #75
Bgw70
Bgw70's Avatar
Hey Shawn, thanks for the reply, I signed up for the newsletter and received confirmation but have not received a discount email yet.
They list a pair at $40, does that sound correct?
Bgw70 is offline
Quick Reply: lexus logo projector puddle light
