sc 430 outside mirrors
Old 06-06-12, 04:17 PM
piclkeball
piclkeball's Avatar
Default sc 430 outside mirrors
I have a 2005 SC and when recently washing the passenger side mirror, i "tweaked" it and now you can use the inside adjustment to move the mirror from side to side but the up and down function on that side does not work nor the downward mirror adjustment when putting the transmission in reverse. The drivers side mirror continues to operate in all functions.
Is there a do it yourself fix?
Old 06-06-12, 04:37 PM
SteadyEddy
SteadyEddy's Avatar
Location: Formerly Easton, Pa. Bradenton FL, now Osprey Fl.
Have you tried tweaking it back a little. It might just be out of range for the motor to pick it up. Worth a try.
Steve4352 (08-30-19)
Old 06-06-12, 06:07 PM
Poqman
Poqman's Avatar
check out this thread. I used it to replace the motors in my mirror. I bought a used mirror for donor parts. Lexus does not sell the motors.
https://www.clublexus.com/forums/sc-...de-mirror.html
Old 06-08-12, 10:56 AM
Harold57
Harold57's Avatar
Do you hear the motor run when you attempt to adjust it? If so, you've probably damaged the gears. Either way, Poqman's suggestion will get the necessary parts for you. I'm not real familiar with the inner workings of the mirror, so I'm not sure if there is something that could have just been knocked loose when you washed it. Worth checking it out though.
Old 06-08-12, 11:32 AM
toxic
toxic's Avatar
Do both mirrors readjust in reverse? Only my drivers side does.
TOXIC
Old 06-08-12, 01:03 PM
VVTiBob
VVTiBob's Avatar
Both mirrors should move when placing the transmission into reverse AND having the L-R mirror selector switch in either L or R not in the center, or neutral position.
Old 07-19-14, 06:44 PM
wmschramm
wmschramm's Avatar
Default Fix SC430 mirrors not adjusting
Here is the fix for my 2002 SC430 mirrors not adjusting. Pull down from the top of the housing, above where it says security.
There are two connectors one black, one white. Unplug them. Re-snap them back into place. The mirrors now adjust left, right, up down and go down when car is in reverse. In the LS forum the owners had to clean contacts to get the mirror working. On the SC I found no contacts even though I unscrewed two little screws inside the housing.
Old 07-20-14, 05:00 AM
FrictionSc
FrictionSc's Avatar
Thanks for the info. I'm having the same issue.
varcity64
01-28-16 06:57 AM
francis123
07-12-14 04:04 PM
MsbTTSupra
03-14-14 04:00 PM
Quick Reply: sc 430 outside mirrors
