keeps popping up
Old 05-23-12, 09:31 AM
bacardi
bacardi's Avatar
Default keeps popping up
dose anybody know to stop the box on from keep coming up on the right side
ok think i got it
Old 05-23-12, 02:07 PM
VVTiBob
VVTiBob's Avatar
Huh?????????? What box? I'm confused.
Old 05-23-12, 03:12 PM
bacardi
bacardi's Avatar
bob
still doing it
Old 05-23-12, 04:44 PM
barncat
barncat's Avatar
Remove the muffler bearings. Then it will stop.
Old 05-24-12, 08:02 AM
Habious
Habious's Avatar
Probably just low on hood coolant.
Just top that off and you should be fine.
Old 05-24-12, 08:57 AM
Yes
Yes's Avatar
ok think i got it
I think your post is missing a word or two.
Old 05-24-12, 09:47 AM
JohnnyCake
JohnnyCake's Avatar
This happened to me a couple of years ago. It turned out that the box dampener on the right side had gone bad and so there was nothing to keep it from coming up. The dealership wanted almost $5,000 to install a new dampener. I did it myself in about 10 minutes. Problem solved.
Old 05-24-12, 09:55 AM
ser67
ser67's Avatar
Check the flange plate, because its probably gone out of skew on the treadle.
Old 05-24-12, 05:11 PM
scyul
scyul's Avatar
Check the kick-down fluid in the reservoir... Level might be low!
Old 05-24-12, 06:12 PM
sebtown
sebtown's Avatar
Radiator bearings, definately radiator bearings.
Old 05-24-12, 06:23 PM
braheem
braheem's Avatar
Not the carbeurator?
Old 05-25-12, 05:03 AM
barncat
barncat's Avatar
Boy, you learn so much neat information on this site!!
Old 05-25-12, 05:44 AM
Stuntman22
Stuntman22's Avatar
Check the Finigan Pin then check the flow of the Dynoflow.
Old 05-25-12, 01:02 PM
sebtown
sebtown's Avatar
May also mant to check for poper alignment of the Johnson Rod
Old 05-25-12, 01:09 PM
VVTiBob
VVTiBob's Avatar
I checked my "Johnson" and it is aligned properly.
sorry, just couldn't resist
Quick Reply: keeps popping up
