Help caliper oil feed line hole stripped.
Old 04-15-12, 10:22 PM
tuterz
tuterz's Avatar
Default Help caliper oil feed line hole stripped.
I was putting in my bbk today and stripped the hole where the oil feeds into the calipers. At first I thought it was the bolt but then I pulled it back out the hole inside was stripped out. What can I do to fix it? Any thoughts? I hope I dont have to buy another caliper.
Old 04-16-12, 10:52 AM
Harold57
Harold57's Avatar
I believe that there is a product called "Form a thread" (or something like that) on the market. I used it about 20 years ago on the bolts that held on my wheel covers and never had a problem with them. However, the brake lines are under pressure when in use, so I don't know if this product is appropriate for the application. Is there an insert that will fit?
Old 04-16-12, 11:08 AM
tuterz
tuterz's Avatar
i think i will try to take it to a machine shop to get it rethreaded.. hopefully it will help..
Old 04-16-12, 06:59 PM
scyul
scyul's Avatar
Tuterz,
You will have to get the hole re-drilled and tapped oversize, and have a slimsert (or an Heli-coil) installed... This procedure requires special tooling and is widely use on aircrafts... Assuming the seal between the hose and the caliper is done with a copper washer (like regular calipers), this should work.
Did you strip it by over tightening, or is it a manufacturing defect? If it's a defect, I would request a replacement... 'cause I assume that these aren't cheap!
BUT DON'T USE ANY KIND OF PUTTY!!! It will definitely not work!
Old 04-16-12, 07:03 PM
tuterz
tuterz's Avatar
I stripped it by over tightening it. I'm bringing it to a shop tm so they can take a look at it. It was the very last step and I was done too. SMH. I was pretty sad about it.
Old 04-16-12, 07:18 PM
scyul
scyul's Avatar
This is what a slimsert looks like...
http://alcoafastener.thomasnet.com/v...tric-oversize?
And I found Heli-coil repair kits on Amazon...
Amazon Amazon
Not sure about your thread size though.
Good luck tomorrow...
Old 04-16-12, 07:46 PM
sebtown
sebtown's Avatar
A new caliper, on line is less than $100. if it were my life behind the brake pedal I would beg, borrow or steal the $100.
Old 04-18-12, 04:14 AM
scyul
scyul's Avatar
Sebtown, You missed the part where Tuterz says its a caliper from a "bbk" (Big Brake Kit)....
Not $100 to replace...
Old 04-18-12, 05:04 AM
gripau1
gripau1's Avatar
The heli coil may fail due to the high pressure brake fluid. I would take it to a machine shop and let them repair it - if possible.
Old 04-18-12, 10:08 AM
tuterz
tuterz's Avatar
I took it to a machine shop. They are gonna retread it for me. I'm picking it up this afternoon. Hopefully it will be fixed.
Old 04-18-12, 06:48 PM
scyul
scyul's Avatar
Helicoils are designed to withstand correct torque value, and are widely used to repair stripped treads in aircraft components.
Typical brake line pressures during a stop range from less than 800psi under "normal" conditions, to as much as 2000psi in a maximum effort. Aircraft hydraulic systems operate at 3000 PSI... Just so you know.
Old 04-18-12, 07:24 PM
tuterz
tuterz's Avatar
so i got my brakes back today.. works perfectly great! .. fixed for 25 bucks! .. yay! got a new pic up in the progress thread!
Old 04-19-12, 08:37 PM
scyul
scyul's Avatar
Cool!
man8959
GX - 1st Gen (2004-2009)
01-16-21 03:48 PM
Wilzzonn
RC - 1st Gen (2015-present)
05-03-18 12:59 PM
Djfoho
Suspension and Brakes
13
09-09-13 08:23 PM
MsbTTSupra
11-11-11 05:27 AM
SISMO817
GS - 1st Gen (1993-1997)
03-27-07 02:13 PM
Quick Reply: Help caliper oil feed line hole stripped.
