Would like to change the interior lighting
Old 01-29-11, 08:10 AM
oneforu2c
oneforu2c's Avatar
Default Would like to change the interior lighting
Good morning to all of you, wondering if anyone can tell me what and or where i can get upgraded (brighter-whiter) interior lighting, i.e map, dome if that is what they call it etc....
please let me know thank you to all of you that have helped me out in the past
Old 01-29-11, 09:00 AM
Harold57
Harold57's Avatar
I believe that a couple of threads have covered replacing the lights with LEDs and have been successful.
Old 01-29-11, 09:52 AM
VVTiBob
VVTiBob's Avatar
Yep LEDs are the only way to go...ijdmtoy dot com is one company. Check out this thread: https://www.clublexus.com/forums/sc-...placement.html
They're great for all the interior lights, I changed all mine.
Old 01-29-11, 10:32 AM
i2fat
i2fat's Avatar
Are there 10 lights total? 2 top front, 1 driver door, 1 driver feet, 1 passenger door, 1 passenger feet, 2 license plate, and 2 trunk?
Old 01-29-11, 10:51 AM
VVTiBob
VVTiBob's Avatar
and two vanity mirror lights. But I left them alone...wife like the yellow cast versus the harsh white.
Old 01-29-11, 10:52 AM
VVTiBob
VVTiBob's Avatar
And don't forget to go to Sylvania dot com for the bulb type...many are different.
Old 01-29-11, 12:32 PM
i2fat
i2fat's Avatar
Where are the vanity lights located? (Dunno what vanity lights are) lol
http://cgi.ebay.com/5050-SMD-6-LED-C...ht_2803wt_1141
Has anyone tried these? Wanted to grab some if they work pretty well.
Old 01-29-11, 01:09 PM
darnot10
darnot10's Avatar
I believe the vanity lights are for the wife's make up mirror! Anyway, I looked at that site earlier and I'm still trying to figure out all the LED lighting in my 2003 SC. Maybe later tonight or tomorrow I will use the search function and try to figure out exactly what I need for each light in the vehichle. I will use VVTiBob's advise and check out the sylvania website for part number comparison, etc.
Old 01-29-11, 01:14 PM
i2fat
i2fat's Avatar
Ohhhh right the..visor lights, so 12 in total.
Old 01-29-11, 01:56 PM
VVTiBob
VVTiBob's Avatar
Yep, 12 counting the two mirror lamps. Ooops I forgot some. Two scuff plate lamps.. but they're seal inside the housing and not replaceable as far as I know, and the four seat belt receiver mechanism lamps are LEDs already. Same for the ignition key lamp.
And the Sylvania site with gives you the correct incandescent type or bulb number, then find the equivalent LED from which ever vendor you choose to you use. There are many vendors and many varieties of LED, color, intensity etc etc.
Old 01-29-11, 02:12 PM
jerzylexus
jerzylexus's Avatar
bob..did you change out the tiiiiny little bulbs underneath that light up the feel area? what are they?
Old 01-29-11, 02:13 PM
i2fat
i2fat's Avatar
So I can't buy 12 of these (http://cgi.ebay.com/5050-SMD-6-LED-C...ht_2803wt_1141) and it'll fit? lol
Old 01-29-11, 03:12 PM
VVTiBob
VVTiBob's Avatar
Jersey... if you mean the footwell lights driver and passenger side. Yes I did change them out..If I remember correctly they were"37".
theodor that exactly what i bought... works for everything but visor and footwells due to multiple connectors in the box. The six LED really improve the brightness in passenger compartment, and nicely illuminate the ground as you open the door.
In the trunk they're brighter too, but because the fixture is shallow the LEDs are not diffused so you can see the outline of the LEDs. Looks like six bright dots.... sort resembles the six side of one die of a pair of dice.
Old 01-29-11, 03:17 PM
VVTiBob
VVTiBob's Avatar
yes just checked the sylvania site for 02 they are the 37 listed as the glove box light. You just need to find the LED match for the 37 bulb.
Glove box
37
37LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Old 01-29-11, 03:20 PM
VVTiBob
VVTiBob's Avatar
in my comment #3 above it points to a previous thread where I posted a photo of those lamps with and without the lens for the overhead light attached.
Quick Reply: Would like to change the interior lighting
