Antenna
Old 06-10-02, 06:54 AM
DNLMD
DNLMD's Avatar
Default Antenna
I have a question about the antenna. Are there 1 or 2 positions. If there are 2 positions, has anyone seen it at the extended position?
Old 06-10-02, 08:43 AM
Larry
Larry's Avatar
Two main positions.........up and down.
Old 06-10-02, 10:07 AM
joeyb
joeyb's Avatar
Yes, there are two position. I'm not sure why (perhaps there are some radio buffs out there) but the antenna changes position above a certain frequency -- around 96FM.
Old 06-12-02, 03:36 AM
MJB
MJB's Avatar
I have a UK conversion, so maybe different, but my aeriel extends differently between AM and FM. I think it goes a notch higher for FM, but it could the other way round....
Old 06-12-02, 04:44 PM
antigeek
antigeek's Avatar
Other Lexus models do this too.
My guess is that it's an FM Diversity feature, optimizing signal pickup based on wavelength.
Old 06-15-02, 05:55 AM
VVT-i
VVT-i's Avatar
It's adjust itself depending on the signal strength. The LX470 you can manaully adjust the antenna from the seperate switch.
Old 06-15-02, 02:40 PM
Lvangundy
Guest
Posts: n/a
90 LS has that, goes higher for AM band.
Old 06-15-02, 08:48 PM
ceboyd
ceboyd's Avatar
Default seems silly..
but I notice it change height for EVERY station switch on FM (I don't listen to AM much but it does go highest for AM(...
I even pre-set 2 stations with the same station and guess what, it still changed height.. goofy thing... I heard it trys for optimum signal pick-up but this constant moving around just seems useless and asking for a part to break right after it is out of warranty...
..but that is just my opinion..
Old 06-17-02, 07:59 AM
DNLMD
DNLMD's Avatar
A constantly moving antenna is certainly more silly than a never moving one.
Old 06-17-02, 01:09 PM
moseman2020
moseman2020's Avatar
I've noticed the same up down when I change FM stations. I thought it was some optimization also...weird though
iolmaster
02-02-24 03:48 AM
bhdan
04-27-18 12:32 PM
Prasha
01-07-13 11:02 AM
additude
09-16-03 03:50 PM
Lexson
SC- 1st Gen (1992-2000)
15
08-29-02 02:11 PM
Quick Reply: Antenna
