LEXLINK help
Sounds like a bad relay in the main brain. Did you call steve at Luxury motor works? He would be your best bet to diagnose it. Do you have the remote top as well ? If so is that working ?
Buddy
Buddy
I see your not getting any response to your problem. I would tell you again to contact Steve . I have the latest version of the luxlink. Mine came with an led harness to plug in as well as a push type plug in switch . These are used to run diagnostics. There is a procedure that you use with the switch and the led light to trouble shoot. Let me know when you get your problem resolved .
Buddy
Buddy
sounds like the chip isnt near the ignition coil or if you used that supplied wire that you wrap around the ignition coil and place the key inside that holder isnt working correctly. I had the same problem before. I just put my chip near the ignition coil and didnt use that stupid key holder with wire thing.
Luxlink
The chip has to be seen in order for the car to start However the engine should crank over. He said that the radio was coming on and the climate control information was lighting up. But the engine would not turn. The starter would not engage. If you dont have the chip in then the fuel is shut off that is how the engine is imbolized . The engine will crank but it wont start
Buddy
Tony
Buddy
Buddy
its where u insert the key, just take a key to the key hole without inserting it. but as mrblister pointed out if its not cranking up its probably not that. sorry buddy, the only thing i can think of is a loose wire or a defective unit
Joe Did you do the original install of the luxlink? If so then you should be able to do the test Steve told you to do. If you did not do the original install Then you might need some help in running the test..
The only place the main luxlink module could be located would be underneath the steering colum. You would have to remove the dash trim panel that is underneath the steering wheel on the floor. It really just snaps off. Then you should be able to loacate the luxlink main black box its approx 4 inchs square. You should be able to find the white wire steve told you about . Just test that according to his notes. If it tests bad then your only option is to exchange the unit you have for the newer generation unit . There is very little room underneath the trim panel so I am sure you should be able to easily find the main box . In the older generation unit like you have they did not come with a balck plastic box for the key and the coil that has been mentioned. If I remember correctly you had to wrap the luxlink coil antenna wire from the luxlink around the key and it would be placed in the general area of the ignition switch. The purpose of this was so when the car would go to start it would be able to recognize the chip so it would then be able to start .The engine would crank regardless of the chip or not but it would only start if it was able to recognize the chip. The newer generation units came with a black plastic box that you would place a key that had a chip in it inside the ribbon coil wire inside of the black box., I think I asked you before did your unit have the remote top as well as the remote start ???
Good luck
Buddy
No I did not install it. I do have the combo unit starter and top.
I will try a key near the key hole first. If the key holder got loose
and it is not close to were it should be that should do the trick.
If that dosen't work I will try to test the white wire. Will have to
borrow a volt meter to test it ?
Thanks for all your help,
Joe
Joe
Luxlink
Joe
Joe
Joe
The key holder if it got loose assuming your model of luxlink came with the black plastic key holder will have no effect on the cranking or not cranking
If the motor does not start to crank over when you try to remote start then it cant be a chip or key issue. If there were a problem with the chip or the imbolizer the engine would still crank. So if your engine does not start to turn over when you remote start then go to that white wire. I believe your model of luxlink did not come with the key holder case. I believe that you had to wrap the coil wire around the key and it would of been located near the ignition switch.
Buddy
lux link install instruction
Joe
Joe
buddy
http://redhat2.admarkonline.com/~lux...on_pdf-353.doc
lexo1998
02-10-24 01:01 PM
saltyreefs
04-18-06 11:46 PM
