VSC lights and ScanGauge - Page 2 - Club Lexus Forums
Thread Tools Search this Thread
Old 02-13-13, 11:11 AM   #16
rustfarmer
Default Thanks!
Awesome, will try this ASAP
rustfarmer is offline   Reply With Quote
Old 05-31-13, 09:50 AM   #17
chrisv78
hsujohn's explanation worked like a charm for me. thanks.
chrisv78 is offline   Reply With Quote
Old 06-01-13, 08:58 AM   #18
hlthlnk
Wow- just had the ck engine light come on due to a bad o2 sensor went to advance auto borrowed their code reader and reset all my codes. Every thing went fine except for the vsc lights light would not reset, I thought I had done something wrong... Perfect timing with this post, it worked like a charm no more lights! Thank you to all that made this post.
hlthlnk is offline   Reply With Quote
Old 06-02-13, 10:47 PM   #19
Alex818
I have the same problem. Except mine isnt a low quality OBD reader. I've used this on over 30 cars and never had any issues but with this SC430 the traction control lights came on. Been on for 2 weeks now, I keep forgetting to try the method.
Except 1 problem: it looks like while both those lights are on i don't have traction control. I punched it half way while taking a left turn the tires spun out at least 20 feet. Pressing the traction button does nothing now.
Alex818 is offline   Reply With Quote
Old 06-03-13, 06:35 PM   #20
Alex818
Update: Used the provided method in the previous pages and threads. It worked for me too. What i'm curious to know is how on earth did these people figure it out
Old 06-03-13, 07:31 PM   #21
hlthlnk
You must believe in the force Luke!
Old 06-03-13, 08:39 PM   #22
Alex818
lol sorry haven't seen the movie
Old 07-26-14, 06:43 PM   #23
Thompaine
Default Thanks!
Thanks Hsujohn! Worked like a charm on my wife's 2005.
Thompaine is offline   Reply With Quote
Old 08-12-14, 05:19 PM   #24
bobster99
Just adding in a thank you and bumping this up so others might see this. What in the world did we do before the internet huh...
This one baffled me and without this list I would still be driving with this light on.
I have a version of TechStream (just google it) using an older netbook and a $25 cable from amazon and I suspect that the $25 cable isn't quite the quality of the $400 cable. The last time I checked for codes something might have happened like I pulled the cable out by accident without shutting off the car. Likely this caused the VSC light to come on.
Techstream didn't see any codes so I was baffled what to do but 5 minutes and a paperclip and my light was off again... Thanks Guys
bobster99 is offline   Reply With Quote
Old 09-12-14, 04:43 PM   #25
mandyfig
mandyfig's Avatar
I had the same issue and followed the steps and nada. Turns out that I was pushing the jumper at the wrong places, wrong end to be exact. Once I figured this out, the VSC flickered and it was gone. I will take it for a test drive later. The VSC and VSC OFF came on shortly after I had the car checked for emissions.
Thank you! I knew one of these days I will use this technique.
mandyfig is offline   Reply With Quote
Old 01-20-15, 06:56 PM   #26
Caseoane
This works! I have no idea what I did, but I managed to turn the VSC light on by messing with my diagnostic tool (the official Toyota one, no less). Light on, but no codes...
I tried everything, and then, when nothing worked, very hesitantly, I jumped the reader like it says here. Voila! Light off...
thanks all!
Caseoane is offline   Reply With Quote
Old 03-10-15, 07:04 PM   #27
Alterious
Alterious's Avatar
Thank you for this guys!!!! I just followed the instructions and voila
Alterious is offline   Reply With Quote
Old 03-11-15, 09:57 AM   #28
mandyfig
mandyfig's Avatar
I have made a permanent tool (jumper) and it is kept in a safe place, in case the VSC lights up again.
Old 03-11-15, 09:06 PM   #29
SlvBullet
SlvBullet's Avatar
Quote:
Mandy that is a great idea. I have custom bent paper clip in the console but always need to look at the socket picture I keep on my phone and struggle getting it the correct holes. I'll order a plug and wire it up to make it easy.
SlvBullet is offline   Reply With Quote
Old 03-12-15, 02:35 AM   #30
Bgw70
Bgw70's Avatar
OBDII male plug, click here.
Bgw70 is online now   Reply With Quote
Thread Thread Starter Forum Replies Last Post
The mysterious link between VSC and the oil control valve (OCV) malfunction reozone LS - 3rd Gen (2001-2006) 19 03-22-17 07:01 PM
Vsc & vsc off 2001 gs300 5280Lexus GS - 2nd Gen (1998-2005) 2 01-22-17 10:12 PM
Techstream, OBD, and the VSC OFF lights Retroplay SC430 - 2nd Gen (2001-2010) 8 09-30-15 12:58 PM
VSC/ABS/VSC OFF lights are on systemover GS - 2nd Gen (1998-2005) 7 10-31-08 02:22 PM
Feeling a little slighted from service experience @ Hennessy maintrain Maintenance 4 10-29-04 08:43 AM
Tags
02, 470, abs, blinking, dash, gs400, gx, lexus, light, obd2, pinout, reset, sc430, scangauge, vsc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
