How to disable tire-pressure monitoring (TPM) system?
Old 09-03-07, 06:01 PM
  #61
rominl
exclusive matchup
rominl's Avatar
wow, 1 sensor per quarter, that's a lot. wonder why that's the case. my original sensors were still fine the day i returned the car, 3 yrs after i took delivery
Old 10-25-07, 03:38 PM
  #62
shairise12
shairise12's Avatar
works like a charm!!! took me 5 minutes!!!! what a relief !!!
Old 10-25-07, 03:40 PM
  #63
shairise12
shairise12's Avatar
Took me 5 minutes!!! what a relief to not see or hear anything to deal with the TPM dudes...
Old 01-16-08, 04:49 PM
  #64
c0wb0y
c0wb0y's Avatar
Originally Posted by tonydt1g3r
The service writer at lexus told me something entirely different today. I have an extra set of 4 TPS sensors and asked him to set them before I mounted them on the car and he said that you have to mount the sensors inside the rim first them put them up to 60psi and program them that way. Is this true or am I going to mount the sensors and be screwed?
well to answer all your questions, on the sc430 you do not have to dismount all four tires to get sensor codes because they are color coded. you just plug the scan tool into the dlc port and you can pull them up that way. and whenever you replace a sensor you have to once again have the scantool plugged in and there is a program for it where you drop all 4 tires down at least 6-8psi in 30 seconds a tire. you have a total of 5 minutes to complete it if you do it with the scantool. and if you do think that you have a bad sensor when you take it to the dealer what they will do is watch the tire pressures being read by the computer and drop all the tires to see which one doesnt move. hope that helps
in other words, with this i would reccomend taking it to the dealer
Old 02-19-08, 08:46 AM
  #65
NUJERZEY
NUJERZEY's Avatar
Thanks Rominl...you're Effin Great....it Works Guys!!!!!!!!!!!!!!!!!!!!!!!!
Old 04-10-08, 04:41 PM
  #66
Yes
Yes's Avatar
this might be a dumb question. but i'm about to attempt this and the shifter **** is on very tight. i don't want to torque it too hard and break something. is there any technique to getting it off? i know on my old mercedes you had to lift up on a lever at the bottom before unscrewing it. but i don't see anything like that on there.
Old 04-10-08, 04:55 PM
  #67
Aristo300
Aristo300's Avatar
It just spins off........
Old 04-10-08, 06:00 PM
  #68
rominl
exclusive matchup
rominl's Avatar
just twist. first time can be harder
Old 04-10-08, 07:51 PM
  #69
Yes
Yes's Avatar
thanks guys. got it. i'll also add that the shift plate took quite a bit of force to get it to budge. it felt as if there were a bit of adhesive maybe. or maybe it's just tight from being in there 6 years. but everything was pretty simple after that.
Old 05-16-08, 08:06 PM
  #70
olsliproc
olsliproc's Avatar
Smile tire pressure sensor
Hi I saw that you are the genius on the sc430 tire pressure sensor valve, the pic is not clear but i love your idea i changed just yesterday and it is driving me crazy the flashing and beeping..!!
could you email me the pic and the instructions please sales@wheelkingfreight.com i will do it asap.
Thanks so much
Tim
Old 05-17-08, 03:29 PM
  #71
olsliproc
olsliproc's Avatar
Default I did the unplug for the tire sensor and what an easy job!!
I did the unplug........... no tools needed... amazing in 3 minutes it was off and like it was never a proble make sure the ashtray is closed before re attaching the moulding!!!
I love this forum.
Tim
Old 06-27-08, 09:55 AM
  #72
lyyca
lyyca's Avatar
Default Sweet! It Works!
Yay, it only took me like 3 minutes to unplug. Thank god! But i am concern about one thing: will this affect anything electronically? Just curious. Thanks!
Old 07-06-08, 11:26 AM
  #73
ozziee
ozziee's Avatar
where do you put the spare tire? will a donut fit when the top is in the trunk?? I just want to get rid of the run flats,,,,
Old 07-06-08, 11:42 AM
  #74
Pearlpower
Pearlpower's Avatar
Ozziee, welcome aboard. A search revealed the following:
https://www.clublexus.com/forums/sho...ght=spare+tire
Old 10-02-08, 03:11 PM
  #75
exesc430
exesc430's Avatar
Thanks rominl, your methods worked like magic.
Quick Reply: How to disable tire-pressure monitoring (TPM) system?
