SC430 wheel fitment
Old 05-04-15, 08:51 AM
  #331
texsexlex
texsexlex's Avatar
Originally Posted by Deuce04
Car with those wheels looks great!
I see your running 18's.Do you think the 19's will be much different?
Thanks so much for photo's
Would be happy with the guards filled as much as yours especially in the rear.
Cheers
....thanks alot....with the 19's, they will fill about the same, just remember the rim will be a be an inch taller, so you'll loose a bit of sidewall.I almost forgot to mention, that my car is lowered some also, but the offset of the wheel is what will help fill the wheeltub & bring the tire out closer to the fender. I've started to look at new wheels & will probably go up to 20's. I want 20x9 (f) & 20x10.5 (r) with offsets in the mid 20's
Old 05-04-15, 07:19 PM
  #332
Deuce04
Deuce04's Avatar
All good.
Will get my wheels machined to the offsets required and look forward to getting rid of the standard wheels!!!
Thank you for the information and pics.Lot happier in the decision process now.
Old 05-07-15, 07:01 PM
  #333
Eddie B
Eddie B's Avatar
Default I think with the right 20's your car will sit right.
...not a problem at all.I'm running 18x8.5 on front,with 20 offset & 18x9.5 on rear,with 25 offset.The front tires are 225/40/18 & rears are 275/35/18
...tried to give you a couple different angles
Dont get me wrong it looks good now! But im curious to see what the 20 will look like on our color cars. Have you decided with the silver, steel metal gray or black faces or a combination of the colors or all chrome?
Old 05-07-15, 10:36 PM
  #334
texsexlex
texsexlex's Avatar
...my first choice would be a machined face with chrome lip. Here is another members car, that is the same color as ours & I love this look....of course I'm not going to copy him exactly , but something along this line is what I'm going to be looking for....
unless I get a deal that I can't refuse
Old 05-27-15, 10:13 PM
  #335
Deuce04
Deuce04's Avatar
Just a quick pic of the new wheels. After the wheels what specs for alignment ??
Thanks for all the advice.
Old 05-29-15, 07:06 PM
  #336
texsexlex
texsexlex's Avatar
....looking good !!!...so what size wheel & tires are those ?...there also is another current thread discussing alignment specs, it should be able to help you some
Old 06-01-15, 04:05 AM
  #337
Deuce04
Deuce04's Avatar
245x35x19 front on 9.5 with 30 offset
265x30x19 rear on 9.5 with 25 offset
Old 06-05-15, 08:56 AM
  #338
Jmoorman11
Jmoorman11's Avatar
Does anyone know this car?
Old 06-05-15, 08:58 AM
  #339
Jmoorman11
Jmoorman11's Avatar
Considering buying it but has tons of miles would like to find out who previous owner was and talk with him or her... It has a club lexus on the rear window
Old 06-05-15, 10:01 AM
  #340
ShawnOk
ShawnOk's Avatar
I've seen that car on this site! I think it might be somewhere in the wheel fitment sticky on the top of the main page. If not there it's in the "pics of you SC (large photo)" thread. If you are able to contact the owner, please let us know what spoiler he has installed. I don't believe it to be OEM. Thanks.
Old 10-11-15, 05:47 PM
  #341
LSchino
LSchino's Avatar
Hello everyone! I just purchased my stock SC430 a week ago and i am ready to replace the pie plates for some aftermarket wheels. Talwang's chart was indeed helpful for me deciding the set up i am routing for, so here is the specs i have in mind:
F: 19x9.5 +22 with 235/40
R: 19x10.5 +22 with 265/35
It will be on stock suspension for now, coilovers will be next around Jan 2016. What do you guys think about the set-up? Thank you all!
Old 10-11-15, 08:10 PM
  #342
texsexlex
texsexlex's Avatar
....you'll be ok with that setup,especially since you're going the stock route in the beginning. The coilovers will allow you to drop it & find your sweet spot without rubbing also...good luck in your search
Old 10-11-15, 09:55 PM
  #343
LSchino
LSchino's Avatar
Thank you texsexlex! Also, on the rears i can push through 275 if i am not mistaken. Will this set-up be flush enough base on your experience?
Old 10-12-15, 01:56 PM
  #344
ned1
ned1's Avatar
Default Running 20's
FYI I running
Tires REAR
285/30R20 ZR. Pirelli PZero Nero 26/1/4" tall
Tire FRONTS
255/30R20 ZR. Pirelli PZero Nero 25-1/2" tall
WORK Wheels 20x10 +37 offset
No wheel well rubbing ever.
Old 10-13-15, 10:44 AM
  #345
texsexlex
texsexlex's Avatar
...you can get away with 275's & I've seen members run 285's on the rear also. With the width & offset that you mentioned,I know you will be ok at stock height & 275's. After you lower it on the coilovers,then you can play with the adjustments to get it close as possible without rubbing.....also, if you've never changed your shocks out,you may rub some on bumpy roads & dips. I never felt like my shocks needed replacing,but after changing wheels/tires, it let me know by rubbing when i hit dips in the road
Quick Reply: SC430 wheel fitment
