SC430 wheel fitment
Old 03-29-15, 12:38 PM
  #316
ShawnOk
ShawnOk's Avatar
Originally Posted by StillLine
Here's some info for you Shawn. BTW, here's the link to the site for wheel/tire comparisons.
Wheel and Tire comparison
Thanks so much for the advice Tex and Still! Awesome chart and website!
Old 04-05-15, 08:19 PM
  #317
ShawnOk
ShawnOk's Avatar
So I just got me "new to me" (used) 20" rims while in Louisiana. I'm not completely satisfied with the look, but for a total of $400, they will get the job done. They are in decent condition and have minimal signs of wear and tear and some slight curb rash and gouges. They came with a full set of tires, but I had to purchase two new cheap tires (Venezia) to avoid rubbing in the front (add $200). The included tires fit without incident in the back. I plan to use these as my winter rims and thus will wrap them in snow tires once I get back to Chicago so I just needed some rubber to get me back to Chicago for the time being. I had the OEM TRD Chrome Rims (18x8+40) and Blizzaks (245/40/18), but used 30mm spacers in the rear to give me a move aggressive look. I had to remove the spacers to make the included tires fit and thus the front stick out a little more than I'd like but once I get the proper winter tires, all will be good. Right now, not rubbing and no need to roll fenders. I've attached a photo pre-detail (no tire shine). More to come later. Thoughts? Comments? Opinions?
Rims: U2 SS5-A
F: 225/35/20x8.5+13
R: 245/35/20x8.5+13
Old 04-05-15, 10:19 PM
  #318
texsexlex
texsexlex's Avatar
Rims: U2 SS5-A
F: 225/35/20x8.5+13
R: 245/35/20x8.5+13
...not bad at all...how's the ride compared to what you took off ???
Old 04-06-15, 04:16 PM
  #319
ShawnOk
ShawnOk's Avatar
Well the ride is smoother but I do get some violent vibration at 60+mph. So I ordered hub centric rings now that I know the wheel bore (73.1). Should get here on Friday and then to Gateway Tire for the TPMS Swap and hubcentric ring install.
Next question for the pros.... what size WINTER tires fit the SC430 in a 20"? I can't find any sizes (via TireRack) in any of the following that I am running...
245/35/20
275/30/20
225/35/20
245/35/20
Any other tires or recommendations? Runflat or Nonrunflat is ok.
Old 04-06-15, 11:13 PM
  #320
texsexlex
texsexlex's Avatar
245/35/20
275/30/20
225/35/20
245/35/20
...those are some of the most common sizes in the 20in tires, so I'm kind of shocked that a winter tire isn't readily available in those sizes
Old 04-08-15, 07:03 PM
  #321
hedjhawg
hedjhawg's Avatar
The link in Post #1 doesn't work - maybe my question was already answered there, but I can't tell. That question is...
What are the OEM wheel specs - particularly Offset and Backspacing?
Old 04-08-15, 08:20 PM
  #322
ShawnOk
ShawnOk's Avatar
I'm 99% sure the following is accurate. OEM tires are 245/40/18. OEM Chrome TRD is 18x8+40, OEM Pie plates/twisties are 18x8+45.
Old 04-08-15, 09:07 PM
  #323
bb430
bb430's Avatar
245/35/20
275/30/20
225/35/20
245/35/20
Go to ebay and type in the size you need, I found some on 245 35 20.
Old 04-14-15, 08:36 AM
  #324
SebSC430
SebSC430's Avatar
Hello,
My SC is equipped in 245/35/20 front and rear in 285/30/20. With this rise, the speed is perfect
Old 04-14-15, 12:47 PM
  #325
Nat
Nat's Avatar
Rims: U2 SS5-A
F: 225/35/20x8.5+13
R: 245/35/20x8.5+13
Good deal....$400. I would've done it too.
Old 05-02-15, 11:25 PM
  #326
Deuce04
Deuce04's Avatar
Default Help
I've been looking at the wheel fitments for my SC430 for some time now and after a few months am confused more than ever!!
Has anyone fitted 19 x 8.5 unknown offset Front with 19 x 9.5 +28 offset Rear ??
Would like fairly aggressive look!
Front tyres 245 40 19 ?
Rear tyres 265 30 19 ?
Any help,ideas welcomed.
Old 05-03-15, 11:16 AM
  #327
texsexlex
texsexlex's Avatar
...you should be definitely ok with that setup. If you want an aggressive look without using spacers,then low to mid 20 offset will be your range & you won't have to do any mods to body. You may need to run a 35 series tire on the front,for a little more clearance,but the 245 width will be ok. The rear will accommodate up to a 285 width,without an issue,using the offset that you mentioned & a 30 series tire. Also, if you haven't replaced your shocks before, the new tire/wheel setup may rub some over bumps & rough roads. I had this issue when I changed my setup,but just took it as a notice that it was time to replace shocks. After replacing shocks,no rubbing at all.....hope this helps some
Old 05-03-15, 08:51 PM
  #328
Deuce04
Deuce04's Avatar
Thanks Texsexlex, Much appreciated.Could you post some photos of your wheels to give me an idea how the sit.
Cheers and thanks again
Old 05-03-15, 09:15 PM
  #329
texsexlex
texsexlex's Avatar
...not a problem at all.I'm running 18x8.5 on front,with 20 offset & 18x9.5 on rear,with 25 offset.The front tires are 225/40/18 & rears are 275/35/18
...tried to give you a couple different angles
TitanG545 (05-04-20)
Old 05-04-15, 03:31 AM
  #330
Deuce04
Deuce04's Avatar
Thumbs up
Car with those wheels looks great!
I see your running 18's.Do you think the 19's will be much different?
Thanks so much for photo's
Would be happy with the guards filled as much as yours especially in the rear.
Cheers
Quick Reply: SC430 wheel fitment
