SC430 wheel fitment
Old 04-11-13, 08:46 AM
  #271
texsexlex
texsexlex's Avatar
Originally Posted by robocloser
hello I just purchsed a 2010 Lexus SC430 and would like to put a set of 25mm spacers on the rear and 15mm spacers on the front with the stock wheels and tires. Has anyone ever one this before? Please let me know. I would appreciate it
...I haven't done this personally, but know that a few of the members have done it without any issues. Hopefully one of them will chime in.
Old 07-20-13, 06:40 AM
  #272
Northernsc
Northernsc's Avatar
Originally Posted by a1is4bits
Here ya go....
Front Wheels: Size 20" x 8.5" , Lip Size 2 1/4" , Bolt Pattern 5 x 114.3 , Offset 40
Rear Wheels: Size 20" x 10" , Lip Size 4" , Bolt Pattern 5 x 114.3 , Offset 45
Front Tires: Toyo Proxes T1R 245/35 ZR20 95Y
Rear Tires: Toyo Proxes T1R 275/30 ZR20 97Y (will go with a T1R 285/30 ZR20 97Y for a little more side wall) Potholes are brutal to band aids. :-(
I know this is conservative but the plans are to lower the car with coil-overs 1" in front and 1/2" to 2" in the back along with removing the heavy stock muffler for some Magnaflow bullets from the resonators back.
I did not want to have issues with the wheel housing lip(s) rubbing the wheels/tires after lowering.
An SC430 project car by WheelExperts Automotive group was my inspiration to do a tasteful executive style build over time:
http://www.wheelexperts.com/gallery/...humbnails.html
My Baby is shown below:
Love the wheels, what are they? (Looking to do the same on my 05 sc)
Thx
Old 08-11-13, 08:51 AM
  #273
Acura2Lex
Acura2Lex's Avatar
I'm planning on going 19x9.5+12 & 19x11+15 with 225/35/19 & 245/35/19 tires respectively. I am on STOCK suspension and was wondering if I need to roll/shave my fenders? Any help would be GREAT. Thankss
Old 10-27-13, 01:15 PM
  #274
SC430LS3
SC430LS3's Avatar
Originally Posted by BLAQ ICE
It's not exact....Looking at the illustration it says 8 inch width + 45 offset 33mm to 0mm. That tells me that I can purchase spacers anywhere between 33mm to 0mm.
I was looking for exact measurements from just inside the fender of an SC430 front and rear. The illustration doesn't do that.
From my reading of the chart, (fix me if I'm wrong), you have 33mm space on the outside of the front and 45mm on the outside of the rear STOCK. go to http://www.rimsntires.com/specs.jsp and enter your stock size 245x40x18x8x45 in the first chart and new size in the second, then scroll down to the table below. As long as "Rim Lip" is less than 33 for front and 45 for rear, you are OK. The difference between the calculated number and 33/45 is the max spacer you can run.
Old 10-27-13, 01:23 PM
  #275
SC430LS3
SC430LS3's Avatar
Also, has anyone put 245x45x18s on stock wheels? Are there front suspension issues? I want to go to 18x9.5e45 Mustang SVT wheels w/ 275x40x18s. Any issues there? Can anyone recommend a supplier for hub centric rings? Thanks for tolerating the newbie.
Old 10-27-13, 01:27 PM
  #276
SC430LS3
SC430LS3's Avatar
IMHO, you are 19mm too wide in front and 23mm too wide in back. As long as the tires stretch that much, you might be OK.
Old 10-27-13, 02:07 PM
  #277
SC430LS3
SC430LS3's Avatar
Originally Posted by braheem
FYI Everyone,
I just installed some rims with 10.5 Wide +39 with 295/30-20 tires in the rear they're flush with the fender when looking under the car I still have at least another inch of space for tire width.
My my calcs,...
1. If I upgrade to an 11 inch rim that would need to be offset by 6mm so It would need a 46 offset to stay flush.
2. If I have an inch of space on the inside I can upgrade my tires by 20mm.
3. If I widen tires by 20mm to 315/25-20 I would have to offset the 20mm by half to stay flush so final offset would be +56.
Have I missed anything in my calcs?
Your numbers S B 45 and 55. you are going to be close to suspension. You probably have more than 5mm clearance on the outside front now. More than 10 mm in the rear. If 55 gets you in trouble, you can space it out a little.
Old 10-29-13, 06:16 AM
  #278
Strikercyb
Strikercyb's Avatar
Can someone chime in if the below set up will fit my sc430?
front: 19x9.5 +35mm with 275/40/19
rear: 19x9.5 +35 with 285/40/19
according to the chart it seems like the set up is leaning toward the conservative side. Is the front too wide? maybe narrower tire? Car will be lowered with megan ez street coilovers. how low can i go with the set up?
Thanks.
Old 11-14-13, 06:28 AM
  #279
Autoplak
Autoplak's Avatar
Default Advice from the CL Oracles
My aftermarket wheels are +35 offset all around. That is +10 offset from the OEM +45. I plan to put 25mm hubcentric bolt on spacers on the rear bringing the total offset to +35.
I do not plan to add spacers to the front as they are already +10 by the wheel and any spacer thinner than 25 is a slip-on and not a bolt-on as I do not want to change the studs.
I have stock suspension.
Are there any concerns with ride, tire wear, safety (etc.) with this setup?
Any advice is greatly appreciated.
Old 11-15-13, 09:14 PM
  #280
akdash1
akdash1's Avatar
What are the wheel widths?
Old 11-16-13, 02:41 AM
  #281
Autoplak
Autoplak's Avatar
18 x 8 all around.
Old 11-16-13, 03:18 AM
  #282
Anion
Anion's Avatar
Thanks.
I'm running
Front: 20x9.5 +0 with 225/35/20 hankook v12
Rear: 20x10.5 +0 with 255/35/20 hankook v12
My front only rubs if ONLY if my steering is turned When I hit a dip or going down a steep driveway... Basically if my steering wheel is straight I can hit bumps go up and down driveways perfectly... I just get the angle first and straighten my steering wheel
As for my rear... I'm rolled and pulled... I still rub only when I hit a good size dip... Even getting in and out of the driveway for me is dangerous... I'm on stock height
Use my info and do a bit of measurement and see... IMO I think UR rear is the main issue... If u keep it stock height
IMO (in my opinion) the front is way too aggressive for stock fenders... My front isn't modified at all... Since I'm getting custom fenders for my front and rear soon it doesn't bother me
Stock height and it cambers
Here's a better picture of how flush my rear wheel is with a slight pull..
Front kinda sticks out a bit but once again it's not modified
Here's a side view... Picture... I hope my experience and first hand info are of use to everyone
Old 11-16-13, 03:28 AM
  #283
Anion
Anion's Avatar
Here's the rear fender unmodified when I was running 275/30/20 Achilles
This is when the suspension was compressed a bit but this should give you an idea of the fitment
Ignore the wavy roll... It's been fixed but this is with a very slight pull after the roll
I hope my setup and explanation cleared up a few question for all the aggressive figments !
Old 11-18-13, 04:09 PM
  #284
akdash1
akdash1's Avatar
18 x 8 all around.
The biggest concern would be to make sure you're buying the spacers from a reputable brand. There are a few horror stories out there about the spacers giving out. The other thing to make sure is that they are torqued properly, and that you check them once in a while to make sure they stay that way. I'm not entirely sure what weight they should be torqued to, but I've seen that information elsewhere on this forum.
This is my setup for the summer. Front's are 20 x 8.5 and 20 x 10 on the back. I'm going to be putting 12 mm spacers on the back and 5 on the front next year, as well as lowering it just a tiny bit more.
I'll post better pictures of my winter setup once I get the spacers in. They're 17 x 7 and a +45 offset all around with 225/45 tires so they have a smaller diameter and the car sits lower. It actually looks surprisingly good and is significantly faster, handles better, and stops on a dime. Also better fuel economy.
Old 11-24-13, 12:09 AM
  #285
Hussam
Hussam's Avatar
Hello Romini,,,
please give me your opinion on this kranze MAGISS I was thinking to put size 20 rather than the original 18 but I don't know what the best width for front and rear wheels
help me please with that
Attached Thumbnails SC430 wheel fitment-wheel_l_kranze_magiss_3.jpg   SC430 wheel fitment-image_wheel_top_kranze_magiss.jpg
Quick Reply: SC430 wheel fitment
