GA Map ECU 2, 3000 1JZGTE A340 Stall, A340 Trans cooler Kit
Old 03-05-17, 06:38 PM
chnk
chnk's Avatar
Default Map ECU 2, 3000 1JZGTE A340 Stall, A340 Trans cooler Kit
I have a few things for sale I need to move out of my garage.
Map ECU 2 piggy back
- LNIB never used
- $300 OBO
3000 rpm Stall converter for a 1JZGTE A340,
- hlped out my 60 ft
- burns out like a champ
- $450 OBO
A340 Transmission cooler Kit,
- Has all fittings needed to go to an A340 and steel braided lines.
- Will include some mounts I made to mount where you see on an sc300/sc400 (these are not professional looking by any means fyi)
- $100 OBO
chnk is offline
Old 03-06-17, 10:20 PM
biggregg24
biggregg24's Avatar
The converter fit a 2jz?
biggregg24 is offline
Old 03-07-17, 12:03 PM
chnk
chnk's Avatar
with the 1jzgte auto flex plate I believe it will
chnk is offline
Old 03-14-17, 07:29 AM
stockhatch
stockhatch's Avatar
What can you foot brake the stall up to?
stockhatch is offline
Old 03-14-17, 07:44 AM
chnk
chnk's Avatar
3000 is what it stalls up to
chnk is offline
Old 03-14-17, 12:00 PM
chnk
chnk's Avatar
Originally Posted by kitabel
Not correct for 2JZ-GTE (turbo), only the GE etc.
Your bell housing should be either J1 or J2 (J3 is TT only)
I had bought a 2jzgte torque converter before and I believe the flex plates are different between the 1jzgte and the 2jzgte a340s,
so it wouldn't work on the 2jzgte a340 but theoretically a flex plate from a the 1jzgte should make this work. I can provide if anyone is interested
chnk is offline
Old 03-15-17, 05:10 PM
stockhatch
stockhatch's Avatar
Strange. If I pull the ebrake and smash the brake pedal, I can footbrake my stock converter to almost 3500... :/
Old 03-16-17, 08:46 AM
chnk
chnk's Avatar
That I never tried, I only brake pedaled and gassed
chnk is offline
Old 03-17-17, 02:27 PM
SC300Pilot
SC300Pilot's Avatar
I'll take the map 2 ecu if it's still available.
SC300Pilot is offline
Golden95SC
Performance & Maintenance
04-01-17 02:53 PM
scsexy
SC400 / 300 Classifieds
12-23-16 06:15 AM
williamb82
03-09-11 12:53 PM
UTSC300
06-21-07 07:20 AM
Quick Reply: GA Map ECU 2, 3000 1JZGTE A340 Stall, A340 Trans cooler Kit
