NY Nissan KA to 1UZFE swap kit+New 6 Puck. Much Cheaper and Stronger Than W58 Swap! $900
Nissan KA24DE to 1UZFE swap kit+New 6 Puck. Cheaper/Stronger Than W58! $900
Hi,
I have a Collins, 1UZ to Nissan KA swap kit for sale $900 OBO. I read that this adaptor also works with the CD009 350Z and 370Z transmissions. The driveshaft and flywheel will have to be replaced if you eventually switch to the CD009.
It includes all of the parts pictured as well as a bag of bolts that is not pictured. It also includes the brand new six puck sprung clutch pictured below.
You get everything except a few small, cheap things or the KA. The kit sells for $1650.00 with the included Aluminum drive shaft and 6 puck
You get:.
Collins adapter plate
Flywheel
Bearing
Pressure Plate
Brand new six puck sprung clutch
Custom aluminum one piece drive shaft.
Bag of bolts
The KA transmission is much cheaper and stronger than the W58. It is closer in capability to the R154.
Buy this kit for $900 OBO and a clean KA for $100-$200 (and a few other cheap parts) and drop it in. The KA pedal setup even fits with a tiny mod.
These transmissions can hold a TON of power in stock form, there are plenty of S13/14's with KA24DE-T's pushing over 600whp with the stock transmission. These transmissions usually run anywhere from $100-200 dollars, since everyone is swapping an SR20 into their S13/14’s. If somehow you blow it up, another one is $100-$200 and not $700-$2000. If you go with the CD009, there is probably no 1UZ that can harm it.
This one adapter plate allows you to bolt together your choice of three different Nissan transmissions.
You can pick either 350Z(Z33) six speed, 370ZHR/350ZHR(High Rev transmission) six speed, or KA24DE 5-speed transmissions. The driveshaft and flywheel will have to be replaced if you eventually switch to the CD009 as these are for the KA but the plate works with either for flexibility down the road.
As I purchased this kit for my 400 and never installed it, I have no personal experience with the parts or the swap and I decided to leave my Sc400 auto for my Wife. She does not want to drive the boosted 5 speed Sc300...... ever.
The seller seemed cool and honest and said he was running the kit on his Sc400 and it was great. He beat the hell out of it and the same tranny is still good and is going into another car.. It would be best sold to someone that knows what they are looking at to verify parts. You can also contact Collins to go over your parts list. Local buyer is a big plus.
KA swap thread:
https://www.clublexus.com/forums/per...tml?styleid=13
KA Transmission nationwide search on Search Tempest:
See a KA endure it's first 1UZ burnout:
<p><a href="https://vimeo.com/46397563">Marco's SC400 1UZ V8 w/ KA trans: first startup</a> from <a href="https://vimeo.com/user3716184">juan diaz</a> on <a href="https://vimeo.com">Vimeo</a>.</p>
Loads of info on the swap: https://www.google.com/search?client....clublexus.com
The KA will hold over twice the power a 1UZ can put out. You can actually abuse it if that's your thing. This would hold on a boosted or Supercharged SC400 as well.
Thank you for looking.
You get:.
Flywheel
Bearing
Pressure Plate
Bag of bolts
KA swap thread:
Studiogeek
SC400 / 300 Classifieds
07-31-15 07:17 AM
MongooseGA
22
04-24-12 05:32 PM
