MD 1/2 JZ Knock sensors, Map sensor, Injectors, throttle bracket
Old 03-26-15, 05:59 PM
SCShawn
SCShawn's Avatar
Cool 1/2 JZ Knock sensors, Map sensor, Injectors, throttle bracket
I am cleaning out some stuff that has just been sitting in my closet.
First I have two Beck and Arnely knock sensors for a 1 or 2jz. I bought these and never used them, they are brand new I paid over forty dollars shipped for these each. My price is 35 shipped for each. ONE SOLD
Next i have some SC300/400 Front lower control arm bushings made by prothane. I only have the bottom and I only have it for one side. The person that pressed out my bushings accidentally pressed out the metal sleeve in the control arm. So i had to buy other bushings that would fit. I still have these brand new never used. Perfect for someone in the same situation.
35 shipped.
I have some stock injectors from my 1JZ. They are yellow tops 380CC side feed. Worked fine when I rand them. 50 dollars shipped for all 6. SOLD
Here we have a 2JZ GTE throttle cable bracket that is polished. I bought this thinking that the 1 and 2 jz had similar throttle brackets. Boy was I wrong. I see that CX Racing is selling throttle brackets now, buy this instead of that tacky junk. 40 buckets shipped.
Lastly is a map sensor from a 1JZ. I sent this to Tweakd performance so they can verify that it is what it is and that it works. I am using a 2JZ one so I have no use for this one anymore unless I want to keep it for a back up or something. Anyways 40 dollars shipped. SOLD
TPS
My phone number is 240 837 3258 call or text me, or you can message me here, I check it probably once a day.
SCShawn is offline
Old 03-28-15, 07:28 AM
99GS420
99GS420's Avatar
In Nedd Of 02 Sensors. Lmk if anything comes up.
Thanks
99GS420 is offline
Old 03-31-15, 07:30 PM
SCShawn
SCShawn's Avatar
Thanks
All i have is the stock o2 sensor that came off the 1jz. I doubt it is any good.
Bump sold 1 knock sensor, everything else is still here.
SCShawn is offline
Old 04-03-15, 01:57 PM
SCShawn
SCShawn's Avatar
Injectors are sold. Bump
SCShawn is offline
Old 04-05-15, 11:42 AM
SCShawn
SCShawn's Avatar
Map sensor is sold. Bump
SCShawn is offline
Old 04-25-15, 08:45 PM
SCShawn
SCShawn's Avatar
Added a Toyota 1/2 jz TPS. 40 dollars shipped. I checked the resistance on this item to make sure it is working.
SCShawn is offline
BigShooter
RX - 1st Gen (1999-2003)
19
02-27-13 07:27 AM
PEARL2
Suspension and Brakes
18
02-28-11 07:59 AM
Inspiredm3
09-01-10 12:30 PM
Inspiredm3
19
08-04-10 10:43 PM
Rich350GT
SC400 / 300 Classifieds
12
06-27-05 01:20 PM
Quick Reply: MD 1/2 JZ Knock sensors, Map sensor, Injectors, throttle bracket
