NC No voucher
No voucher
ID 1000CC injectors with plug and play harnesses. Low miles, no issues. $480 Shipped
Alky Control progressive meth/alcohol injection kit with SC reservoir. Twin nozzle set up. Works great. $225 Shipped
2JZ Coil ignition setup. IS300 Coils, Toyota igniter and pig tail for easy wiring, new plug wires, new coil harness. Everything is in good working order. Ditch the distributor! $180 Shipped
All prices are OBO. Very low miles on this stuff. Everything is in very good shape. My camera just sucks and makes everything look like ****.Text 828-989-3946 for fastest response.
The pigtail plugs into the igniter. If you splice the wires using the pigtail, you don't have to run an individual wire to each terminal pin on the igniter. Looks/functions better.
More info on coil set up...
https://www.clublexus.com/forums/per...coilpacks.html
Yup, cleans the bay up nicely, you can use a cheap XS Power manifold and not have to clock anything, and good for high HP set ups. Don't have to mess with DLI
The exhaust is off my SC. Shipping is not included in the price.
Any pics of the exhaust installed on the car? I assume this will bolt up to the typical style downpipe most of us NA-T people have (like can be found on ebay)? Hard to tell in those pics if the first pipes flange has the slight angle needed to bolt up to that style down pipe.
Any idea what it'd cost shipped to the Minneapolis area (55449)?
Only pic I could find of the exhaust. Bolted up to my XS Power down pipe, I'm assuming it'll work with all Chinese down pipes. Not sure on the shipping. I'll do it for $350 shipped if you really want it.
