FL Built 2jz 1.5 0miles!!
up for sale is my freshly built 2jz motor. i decided to go a different route this motor has never even been started this motor has 0miles!!! so im looking to get 3500.00obo here`s whats done to it.
Contact me at 561-654-9217
Contact me only if your serious bought purchase!
Brand new 1.5j long block 0miles
contains:
Bored 2jz block to 87mm
Block decked
Arp main studs
Acl main and rod bearings
polished crank
New Scatt rods with arp rod bolts
New Wiseco pistons
Cometic head gasket
Arp head studs
1jz head
Valve job with all seals
New Titan cam gears
Stock cams
New factory oil pump
New factory crank gear
New gate racing timing belt
New mk4 engine mount brackets
rear oil sump/oil pan.
history about the motor/build
the 2jz-ge block was decked and honed to 87mm,only the block is from a ge the rest is from gte the rest why a ge block was used cause it has a higher pressure oil pump. The wiseco pistons and scatt rods were placed in.The Crank Shaft was spec and polished to fit the new ACL bearings. Main studs and rod bolts are from ARP, as well as the head studs.
A cometic metal head gasket was specialed ordered to compliment the build:87.5 bore seal and 1.1mm for quench spec. A new factory gte oil pump was put on along with a gte crank gear for the ecu to recognition from the crank sensor.a 1jz head was used cause it made it able to bump the compression ratio close to a 9.5.1 to reduce turbo lag the head has been polished as well.The complete valve train is stock with all new seals.Titan cam gears were put on as well as a gate racing timing belt.
there was no short cuts taken here. this motor is built to really kick some *** and take names.
that pretty much sums it up im willing to ship as long as the buyer pays all exp..
thanks all.
contains:
Block decked
Arp main studs
polished crank
New Wiseco pistons
Cometic head gasket
Arp head studs
1jz head
New Titan cam gears
Stock cams
thanks all.
Vouch received from shaodome.
Sellers feedback from other forums:
http://www.ka-t.org/forums/viewtopic.php?f=19&t=60207
http://zilvia.net/f/sale-items/53230...ml#post5385734
Refer me back to this sale if asked again for a vouch.
Thank you very much Jordan an supra dr. I understand your just looking out for your members best interest and you will do what needs to be done to protect the member from scammers and crooks. As everyone can see here im a legit seller. I'm sorry my feedback on this forum is not yet rated but I am looking to change that.
I dont do my posting here for the fact that I own a 240sx with a 1jz in it so most of my time is spend on 240 forums. I do have this motor listed on a few sites as everyone can see and im well known on all of them. I'm willing to answer anyone questions they may have please feel free to text call pm reply in this thread with any questions u may have
Thanks again all and thanks for looking.
Thanks for the offer but ill have to pass on it.
