what was deleted for ac and why ..i see map and iat plugs .. what type of inj plugs are there .. is there also plug for crank position sensor as i have a 97 ..
The plug that goes to the AC is not there I wasn't planning to run an AC so I told them not to bother with the AC wiring.. yes map and Iat plugs are there. The injector plug type I believe are the standard evo14 like some FIC and Injector clinic and other injectors. Crank sensor is not there but its wired to run the VVTI coil pack setup and 7mgte CPS.
