FL Single Turbo 1JZ FULL SWAP, Exedy HyperSingle, MC R154
I'm selling my 1JZ setup out of my racecar. I don't want to hear any questions anyone has. Had something serious come up and right now isnt race car time. Keeping my chassis, just going a different route for a while. It's better for my business.
Motor is fresh! 50miles on it since being resealed.
JZX90 front sump 1JZ from JDM Orlando
Motor has:
New Plugs (BKR 7E)
New Heat Shrinked Coilpacks
New Valve Cover Gaskets
New 2JZ water Pump with OEM GTE backhousing
New Timing belt
New injector cushions
New PCV valve
Resealed upper/lower pan with Toyota FIPG
Custom bracket to run ps without ac
Custom BMW PS reservoir
Powdercoated Fuel Rail
Powdercoated pulleys
Painted valve covers
Painted upper/lower intake manifold
Painted upper pan
Painted coolant neck
Block stripped and painted with VHT high heat enamel
Holset HY35
-shaved/powdercoated compressor housing
-welded/ceramic coated exhaust housing
-recently rebuilt
-modified to run v-band
Sweet awesome dump pipe (header wrapped)
Downpipe 3" 304stainless V-band (header wrapped)
440cc MK4 Supra injectors
Map ECU 1 with wiring harness/serial connector
Tial 38mm V-Band wastegate
Modified/Braced Manifold to run T3/Tial 38mm
-4 feed line with goodyear fire sleaving
-10 return line
Oil drain fitting
Oil feed fitting
All new gaskets
Stock JZX90 engine harness reloomed
Stock Igniter chip
Stock Soarer ECU
Stock 370cc injectors included
$2500 firm, not obo. This is a deal considering what it all comes with.
This is ready to drop in and go, real turn key swap to make 400whp with good response. Motor is in my car still running, you can hear it run.
$2500.
If you want a R154 (Everything included new oem slave, new mount, mc bushings, shifter extension, shifter, MC thrust washer) with Exedy Hypersingle included, everything to run it.... $4800 firm, not a penny less.
Motor has:
New Plugs (BKR 7E)
New Timing belt
New PCV valve
Painted upper pan
Holset HY35
-recently rebuilt
-10 return line
Oil drain fitting
Oil feed fitting
All new gaskets
Stock Igniter chip
Stock Soarer ECU
$2500.
2.5tsoarer
Performance & Maintenance
06-16-04 04:24 AM
