KY F/S Complete sc300 5spd swap front to rear every nut and bolt
Old 11-19-12, 06:49 PM
thebadz32
thebadz32's Avatar
Talking F/S Complete sc300 5spd swap front to rear every nut and bolt
Complete 5-spd swap from 1993 sc300 everything down to every nut and bolt
First & Last name: Chris Emmons
email: thebadz32@hotmail.com (better to message here or text me)
phone number? 502-418-0086
City :Louisville
State :KY
Zip code : 40229
As the title states i have a complete 5spd swap from a running 1993 5spd sc300. The car had 168k miles on it. This is everything as listed
>w58 transmission
>trans mount and cross member
>clutch flywheel and pressure plate (could use new clutch) didnt look that great but didnt slip
>Clutch slave and master cylinder These were newer but unknown milage they look new and found the old parts in trunk
>oem 5 speed rear end complete pumkin
>oem drive shaft front and rear halfs (center carier bearing is shot) sure your factory auto could be used with this
>oem sc300 bent neck shifter with **** (no leather on ****) and inner shift boots
>5-spd shifter bezel (leather ir ripped and pretty crappy)
>5-spd ecu
>5spd clutch and brake pedal asembly
>5-spd cluster (i will be keeping the one that reads 168k miles it will be replaced with one that reads 308k miles changes daily as its still in the car i drive daily. all back lights work alnog with gas and temp needles speedo and tach needles are burnt out.
>oem hard line from clutch mc that goes to the soft line on the slave cylinder both are included.
>every nut and bolt from the 5-spd swap all labeled in there own zip lock bag to keep guess work down. i would recomend replacing the flywheel bolts as those are stretch to yield although i have reused them in the past with no problems.
Im sure im leaving things out here but this is literally anything and every thing you need to do a factory 5-spd swap on your car if its not listed and you need it just let me know and it will be thrown in as im sure i have forgot a few things. hear are a few pics not every thing is shown as a few parts are still in the car they will be pulled out this week.
On for the nitty gritty asking $1800OBO may consiter trades/partial trades for parts for my supra im building 6spd tranny rear end ect ect never hurts to ask. For the time being this is local pick up only. please feal free to call or txt any time for best and fastest responce (502)-418-0086
I WILL NOT PART THIS OUT
Attached Thumbnails F/S Complete sc300 5spd swap front to rear every nut and bolt-clublexus1.jpg   F/S Complete sc300 5spd swap front to rear every nut and bolt-clublexus2.jpg   F/S Complete sc300 5spd swap front to rear every nut and bolt-clublexus3.jpg
thebadz32 is offline
Old 11-19-12, 06:58 PM
thebadz32
thebadz32's Avatar
Mods i have vouches on the way.
Old 11-19-12, 07:13 PM
hksnlper
hksnlper's Avatar
I vouch for thebadz32. Honest guy.
hksnlper is offline
Old 11-19-12, 09:21 PM
YeA 2jZ
YeA 2jZ's Avatar
vouch for seller, honest guy
YeA 2jZ is offline
Old 11-24-12, 09:21 AM
thebadz32
thebadz32's Avatar
sold payed for and picked up
nyctrini1
SC400 / 300 Classifieds
08-02-12 07:57 AM
cartmill
18
06-12-10 08:34 PM
captainsc
Performance & Maintenance
11-29-09 11:14 PM
94_soarer
09-28-09 08:11 PM
MadMaxxNA
07-01-05 12:21 AM
Quick Reply: KY F/S Complete sc300 5spd swap front to rear every nut and bolt
