OK Cleaning out the Garage
Cleaning out the garage. All parts are OBO. I can be reached by phone or text at 918-200-9658. All prices include shipping.
JDM GTE Intake Manifold. Professionally ceramic coated inside and out polished aluminum. $200 shipped
GTE Fuel Rail. $40 shipped
JDM GTE Traction Control ECU. $100 shipped.
2.5" 4 ply silicone coupler. $40 shipped
3" x 2.5" Turbohoses.com 90 degree transition silicone coupler. $60 shipped
DevilsOwn Progressive Methanol kit with twin M7 nozzles, controller, pump, y fitting, line and check valve. $250 shipped
Supra Twin Turbo Throttle Cable made by Beck/Arnley. $75 shipped
8920 MSD Tach Adapter. $50 shipped
SP Racing Billet Timing Belt Tensioner Bracket. $280 shipped
2 x Stock GTE Timing Belt Tensioners. $50 shipped
GM Flex Fuel Sensor NEW. $300 shipped
2JZ-GTE Stock Cam Gears. $50 shipped
Genuine Toyota Valve Stem Seals. $40 shipped
Starter from JDM 2JZ-GTE unknown condition. $80 shipped
2JZ-GE Lower Thermostat Housing. $40 shipped
TIAL 40mm Wastegate. 4 bolt flange. Comes with fire ring. $200 shipped.
Set of 12 NGK V-Power Spark Plugs. Part No 4554. NEW $30 shipped.
Function7 Aluminum Oil Return Flange. 1/2 NPT. $30 shipped.
PHR Fuel Pressure Regulator Mounting Bracket. $100 shipped.
V160 Slave Cylinder. $80 shipped
A340E Transmission Mount. $50 shipped
2x Greddy Blow Off Valve Flanges. Mild Steel. $60 shipped
Monster Cable Distribution Block $30 shipped
Stinger HPM Series 150 Amp Fuse $15 shipped
SeoulMan24
SC400 / 300 Classifieds
11-29-14 04:37 AM
Cashflo
07-31-11 11:29 PM
LexusFTW
17
05-18-10 08:35 AM
