power locks
Old 06-06-15, 04:07 PM
smksc430
smksc430's Avatar
Default power locks
From both the key remote and inside the car the power locks only occasionally respond. Currently most of the time just the driver side os working. Acts the same when the car is running and when it is off. Seems like the first time i hit lock or unlock it works but repeadelty doing it it stips moving the lock. Any ideas. Bad relay?
Old 06-07-15, 03:08 AM
Bgw70
Bgw70's Avatar
Could it be the door lock actuator, located inside the door?
Old 06-07-15, 09:17 AM
Helogadget
Helogadget's Avatar
I have read where the lock actuator motors get weak over time. Below is a thread that addresses this. There is even a DIY for the not faint of heart that goes into cleaning the little motors and making them work right again.
Here's the thread https://www.clublexus.com/forums/sc-...r-removal.html
Old 06-07-15, 07:14 PM
ShawnOk
ShawnOk's Avatar
My passenger side does this also, but only when I try to cycle the lock/unlock repeatedly back to back. It's like the actuator is getting weaker and weaker with successive cycling. It works perfectly fine with normal everyday (vs. excessive) operation, though.
Old 06-09-15, 10:29 AM
Harold57
Harold57's Avatar
Is there any relation to outside temperatures? (If the actuators do the same thing in the cold of winter, the answer is no.)
Old 06-09-15, 02:24 PM
01gs3
01gs3's Avatar
Definitely sounds like an actuator issue. The 2nd gs is plagued with this problem.
There's another alternative of just replacing the small motor that powers the actuator.
Either way, the struggling off the door locks trying to turn over are a sign of wearing down.
Joeyc850
03-14-15 07:51 AM
Stemmer
RX - 1st Gen (1999-2003)
01-06-14 03:03 PM
gsenthil
02-19-13 03:39 AM
ALLWiTE2JZ
SC- 1st Gen (1992-2000)
06-28-10 08:36 AM
Moogy
10-28-09 02:33 PM
Quick Reply: power locks
