Go Back   Club Lexus Forums > Lexus Model Forums > SC Models > SC 430
Sign in using an external account
Register Forgot Password?
Wheel??????
Thread Tools Search this Thread Display Modes
Old 02-26-15, 12:30 PM   #1
Countdamon
Trader Score: (0)
Default Wheel??????
Looking for people who are running on 20's. I'm thinking of going that route. I have dropped mine 2 to 2.5" Will I rub, and how much offset can I safely get away with. Of course I would like an aggressive stance, but I really don't want to deal with rubbing issues.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
Countdamon is offline   Reply With Quote
Old 02-26-15, 12:40 PM   #2
bacardi11
Trader Score: (1)
nice about lower the car 2' or 21/2 is great what about inter tire ware.
__________________
02 Midnight Pine Pearl: Clear Corners Headlights Duel Flashers Clear Corners Clear Led Front and Rear Markers 18" Work Rims VMS Lugs Gen4 Mod. Megan Mounts Swift Springs Bilstein Sport Front and Rear Dr Gas Mufflers w / X Pipe + Tips TM Poly Upper and Lower Control Arm Bushings Poly Steering Bushings Figs 30mm Solid Sway ISF 17mm Sway Motorsport Tech Spacers Focal 1 Amp Polk Sub Dc Gold Speakers Trans. Pressure Mod Spare Tire Mod Sprintboost TRD Door Stabilizers Carbing STB K&N Lithium Battery
bacardi11 is offline   Reply With Quote
Old 02-26-15, 01:05 PM   #3
Harold57
Trader Score: (0)
I believe that there were a couple of threads about calculating the offsets a few years back. You might do a search on those. IIRC, someone did a fair amount of research.
Harold57 is offline   Reply With Quote
Old 02-26-15, 01:26 PM   #4
Countdamon
Trader Score: (0)
Yeah Harold, I did find some threads, what concerned me was the guy who posted a graph, said if your running 20"s and lower, its going to rub, but it seemed like so many people are managing to run 20"s just fine, so which is true. Can I run them without rubbing, I'm simply not sure.
Old 02-26-15, 03:56 PM   #5
lbintab
Trader Score: (0)
lbintab's Avatar
Lbintab
I run a 20x10.5 +25 front and rear and it's fine. I run a stretched tire though. I could honestly go 10 to 15 mm more aggressive in the rear. The front do stick out but they car will be on air soon and I'm positive it'll clear fine. As of right now it's stock height and I have no rubbing issues.
lbintab is offline   Reply With Quote
Old 02-26-15, 11:05 PM   #6
texsexlex
Trader Score: (2)
texsexlex's Avatar
Send a message via Yahoo to texsexlex
...hey Count from my research, it will definitely depend on your width & offset. Alot of the guys that have gone staggered are doing 20x8.5 (f) & 20x10 (r)....with an offset in the mid 20's to low 30's, you shouldn't have an issue.It will depend more on the tire size then. I'm thinking about moving up to 20's myself & will probably go with a setup similar to what I described or 20x9 (f) & 20x10.5 (r). With this setup, I'll probably look for offsets in the 30's to be safe. I'm lowered about 2in. with 18 staggered now & no rubbing issues. I've talked to a few guys with setups like Ibintab or even more aggressive,most end up doing a stretched tire to help prevent the rubbing issues...hope this helps some & any other input is welcomed
texsexlex is offline   Reply With Quote
Old 02-27-15, 12:06 AM   #7
Black31385
Trader Score: (0)
Quote:
Can you post a pic of your car with 20's on stock height
Black31385 is offline   Reply With Quote
Old 02-27-15, 07:03 AM   #8
Countdamon
Trader Score: (0)
Texlex, that is the exact setup I'm looking to do. Just wish I knew for sure there wouldn't be any issues.
Old 02-28-15, 06:37 PM   #9
texsexlex
Trader Score: (2)
texsexlex's Avatar
Quote:
..you should be ok with that setup, because it's relatively conservative, compared to alot of guys here.I forgot to ask if you used coilovers or springs to drop yours ? Initially when I lowered mine, it let me know it was time for shocks,because of some rubbing on dips & bumpy roads. I installed new shocks & no issues after that.
Click the image to open in full size.
...this is a pic of the drop with the 18's on it, before body kit
...no changes to the drop, but body kit added
Old 02-28-15, 07:32 PM   #10
bacardi11
Trader Score: (1)
tex
I like that with the body kit. and the 18"s nice.
__________________
Old 02-28-15, 11:55 PM   #11
lbintab
Trader Score: (0)
lbintab's Avatar
Lbintab
Old 03-01-15, 11:34 AM   #12
ShawnOk
Trader Score: (0)
ShawnOk's Avatar
I'm running 20s also. 20x8.5 front, and 20x10 rear. I'm on Roderick RW2 Cinque Black Machined Face with Chrome Stainless Steel Lip. I don't have any drop but no rubbing at all. In the future I will add coilovers (with some drop), and a body kit.
__________________
Check The Lex... http://www.clublexus.com/g/album/231622
ShawnOk is offline   Reply With Quote
Old 03-01-15, 02:42 PM   #13
texsexlex
Trader Score: (2)
texsexlex's Avatar
Quote:
Originally Posted by bacardi11 View Post
tex
...thank you sir
Old 03-02-15, 06:20 AM   #14
Countdamon
Trader Score: (0)
Thanks Texlex, I was trying to avoid stretch tires but perhaps that might be my best option. I have the same setup now as you, and it looks like we have the same plan to go to 20"s, right down to the offset. I'm thinking +30 front, and +34 back.
Old 03-02-15, 11:26 PM   #15
texsexlex
Trader Score: (2)
texsexlex's Avatar
...I'm thinking about staying away from the stretched tire also. With the offsets you mentioned, you should be able to do a 275/30/20 & no issues.I already have a set of 285/30/20's, so i'm probably going to go that route...now the search for wheels !!! I'm not in a super rush, but if a very good deal falls in my lap then I'll jump.I need to do a few things around the house, before I spend some more money on the car, that way my wife thinks i"m responsible !!!
Similar Threads
Thread Thread Starter Forum Replies Last Post
Calipers Covers Rubbing d2w4x8nb GS - Fourth Generation 11 08-11-14 09:23 PM
2000 lexus es300 suspension acc ES300 and ES330 2 05-10-13 10:06 PM
Rubbing fix? JRumbarto IS - Second Generation 14 04-06-13 10:36 PM
Getting rid of Rubbing 2BENVD Suspension and Brakes 18 11-28-12 10:07 AM
**Rubbing noise need help** 2slixx IS - Second Generation 9 10-26-12 11:57 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
